[QGIS-Developer] [Qgis-user] [osgeo4w-dev] QGIS 3.18.0 and QGIS 3.14.4 (LTR) packages released and OSGeo4W reboot
Jürgen E. Fischer
jef at norbit.de
Tue Feb 23 12:43:32 PST 2021
Hi Idan,
On Tue, 23. Feb 2021 at 22:24:17 +0200, Idan Miara wrote:
> Thanks for all that great work!
> Are there any instructions on how to use the scripts to build the packages?
No. Just some quick notes: you just need to set OSGEO4W_REP to where the local
package repository should be placed, goto src/$package/osgeo4w and run
package.sh from
a cygwin shell.
That should fetch the sources, possibly patch them, create a local osgeo4w
install with it's build dependency, build the sources, package them and upload
them (unless you set OSGEO4W_SKIP_UPLOAD).
There's no list of expected cygwin packages yet and no automated triggering of
rebuilds of reverse dependencies. It also expects an installed version of
Visual C++ 2019 in "Program Files". The mingw env for GRASS should be set up
automatically.
> Did you consider building a python gdal/proj package that could be
> installed on the normal python distribution as well as on OSGeo4W?
No.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210223/9c630304/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210223/9c630304/attachment.ksh>
