[QGIS-Developer] Docker pull rate limit / Travis
Matthias Kuhn matthias at opengis.ch
Mon Jan 4 04:20:04 PST 2021
Good move, thanks Alessandro.
There was recently also a discussion about moving from travis to github
workflows.
In combination with this, I assume the base image could also be cached
directly inside the github registry (
https://docs.github.com/en/free-pro-team@latest/packages/guides/about-github-container-registry
This might also bring quicker builds because it's in the same network /
tightly integrated with the service.
Just to keep that in mind too
Matthias
On Mon, Jan 4, 2021 at 10:29 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Mon, Jan 4, 2021 at 10:21 AM Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> > On Mon, Jan 4, 2021 at 10:17 AM Richard Duivenvoorde
> > <rdmailings at duif.net> wrote:
> > > Yes, I hit that too. thanks for bringing this up!
> > > Another idea: as the docker is actually more or less 'static' (??? or
> is is pushed to hub on every build ???), can we (or Travis) not 'cache' it?
> As in" place it somewhere so it can be 'created/started' fresh any time,
> but not 'fetched' upon every build?
> > > Or does this loose the whole purpose of this...
> > > Caching could be: put the image on some webserver of somebody with
> 'unlimited' bandwidth (like some universities, providers or
> (unix)usergroups?).
> > I think that might work, the deps image is a base image and it doesn't
> > change so often.
> > > BUT: As QGIS is getting bigger and bigger, we have to find solutions
> for this kind of 'size'-issues when using 'free' services. Same with for
> example the use of OSM-tiles or Nominatim-service, Transifex etc etc... We
> have to be either creative/clever, OR setup our own stuff...
> > > Regards,
> > Yeah, let's just hope GitHub will remain free or we will have bigger
> problems ;)
> > In the meantime I can fill up the form
> > https://www.docker.com/community/open-source/application if noone has
> > already done that.
> Done ^^^ let's see if that works.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210104/afa5d738/attachment.html>
More information about the QGIS-Developer mailing list
