[QGIS-Developer] Add GRASS addon to QGIS?
Richard Duivenvoorde rdmailings at duif.net
Fri Jan 8 03:22:59 PST 2021
Hi Devs,
In the Processing algorithms there is an algorithm 'Transect', which puts 'transects' on the vertices(!) of a Linestring.
For a 'problem' I have I need the transect to be on known distances along the Linestring (so INdependent) of the vertices of that LineString.
(the main problem are the vertices in the lines when the line makes a turn (is not straigh). For straight lines I can use densify to add the right amount of vertices)
If I am correct, this grass addon, is exactly what I need:
https://grass.osgeo.org/grass78/manuals/addons/v.transects.html
But, by default it is not available in QGIS algorithms.
You even have to add it to GRAAS: you have to add it with:
"g.extension extension=v.transects"
(from https://gis.stackexchange.com/questions/290595/where-is-the-v-transects-algorithm-in-qgis)
The final solution is a Processing model, so my question is if I can (easily) make that Grass algorithm work in a Processing Model?
Thanks for any pointers/input.
Regards,
More information about the QGIS-Developer mailing list
