[QGIS-Developer] Travis failing in QGIS-Documentation
Alessandro Pasotti
apasotti at gmail.com
Tue Jan 12 02:00:01 PST 2021
Thank you Matthias!
Just a side note: this is the second time that a failing test in the
documentation helps to discover an unnoticed issue on QGIS master, it
means that the documentation tests are also useful for the general
purpose of QA in QGIS itself and not only for documentation.
On Tue, Jan 12, 2021 at 10:55 AM DelazJ <delazj at gmail.com> wrote:
> Hi,
> Back to green. Thanks, Matthias.
> Harrissou
> Le dim. 10 janv. 2021 à 22:12, Matthias Kuhn <matthias at opengis.ch> a écrit :
>> Part 3 : make sure if the build fails docker images are not published in the future
>> On Sun, Jan 10, 2021 at 6:07 PM Matthias Kuhn <matthias at opengis.ch> wrote:
>>> Hi,
>>> It seems that something is broken in building the "custom widgets qt creator plugin" and that our CI didn't detect that.
>>> Part 1 : make sure this doesn't happen again. The ci builds now with customwidgets: https://github.com/qgis/QGIS/pull/40929
>>> Part 2 : fix the build
>>> Matthias
>>> On Sun, Jan 10, 2021 at 3:48 PM DelazJ <delazj at gmail.com> wrote:
>>>> Hi devs,
>>>> Just to report that the master code tests infrastructure in QGIS-Documentation seems broken. This is likely not due to some sample codes in the docs since we did not change code recently, and the tests not just run I suspect it's something in QGIS code or in the docker image; the setup code fails with "ModuleNotFoundError: no module named qgis". https://github.com/qgis/QGIS-Documentation/actions?query=workflow%3A%22Doctest+build%22+branch%3Amaster+event%3Apush
>>>> 3.16 is running fine afaict.
>>>> Thanks for any help/fix,
>>>> Harrissou
>>>> Le ven. 9 oct. 2020 à 15:08, DelazJ <delazj at gmail.com> a écrit :
>>>>> Hi Matteo,
>>>>> I had opened an issue report to provide instructions on how to build the doctest (https://github.com/qgis/QGIS-Documentation/issues/6064). And I just noticed (sorry!) that Alessandro provided some feedback (in substance, "docker is the best route now").
>>>>> regards,
>>>>> Harrissou
>>>>> Le jeu. 8 oct. 2020 à 08:16, matteo <matteo.ghetta at gmail.com> a écrit :
>>>>>> Hi Harrissou,
>>>>>> I don't have any answer for that, but it is the SAME error I have on my
>>>>>> local machine with a compiled version (or even the installation from
>>>>>> package) of QGIS.
>>>>>> The only way for me to run the tests locally if using docker.
>>>>>> I'm taking advantages of your mail to raise this problem (again) :)
>>>>>> Cheers and thanks
>>>>>> Matteo
>>>>>> _______________________________________________
>>>>>> QGIS-Developer mailing list
>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
