[QGIS-Developer] Avoid overlap settings issue
uclaros
uclaros at gmail.com
Tue Jan 12 06:52:33 PST 2021
the advanced configuration right now selects the layers that one wants to
avoid overlapping *with*. We could have a second checkbox on each layer that
will select the layers that one wants to avoid overlaps *on*, but that will
complicate things visually.
I think it would be better to add a key-bindable master on-off switch and
have avoid overlap function like snapping does: either on or off, and if on,
current layer or advanced mode. If one does not want snapping when editing a
specific layer he temporarily disables snapping, so he could do the same
with avoid overlap; on-off toggling is easier than drop-down selection and
key-bindable makes it even easier.
Another approach would be to let the user decide on feature creation. Make
"avoid overlap for this feature" available on the attributes dialog or spawn
a confirmation dialog on paste. This will definitely help with accidentally
forgetting avoid overlap enabled (been there, done that!)
Regards,
Stefanos
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
