[QGIS-Developer] Python connection to Microsoft SQL Server database
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Sun Jan 17 04:58:30 PST 2021
I’m trying to get some data from an MS SQL Server database using the QSqlDatabase QODBC driver.
I’m struggling to find an example online…I know Microsoft SQL is avoided in most cases but does anyone know the format for the connection string to put under setDatabaseName?
Ideally I want to connect using the users windows credentials so I’m hoping I don’t need to send it a username and password but just the host\instance, port and database name.
Thanks in advance 😊
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210117/8451371f/attachment.html>
