[QGIS-Developer] Rscript load output into qgis from folder
Enzo Cocca
enzo.ccc at gmail.com
Thu Jul 1 04:48:41 PDT 2021
Hi again,
At moment the solution I found it is this but is not very great.
So I add two R packages more (GmAMisc to import raster and vector, and tkcl
to print a message box)
below the code:
##load_vector_using_rgdal
##load_raster_using_rgdal
##movecost script=group
##DTM=raster
##Origin=vector point
##Destination=vector point
##Movecost=name
##Move=number 8
##Breaks=number 0.5
##Function=selection
t;tofp;mp;icmonp;icmoffp;icfonp;ug;alb;gkrs;r;ree;hrz;wcs;p;vl;ls;b;icfoffp
##Time=selection h;m ;
##Outp=selection r;c ;
##Return_Base=selection TRUE;FALSE ;
##Cognitive_Slope=selection FALSE;TRUE ;
##Critical_Slope=number 1
##Walker_Body_Weight=number 70
##Carried_Load_Weight=number 0
##N=number 1
##Speed=number 1
##Zoom_Level=number 9
##RL=number 2
##CL=selection TRUE;FALSE ;
##DL=selection TRUE;FALSE ;
##CB=number 0.6
##CLL=number 0.6
##Output=output folder
##Output_Isoline=output vector
##Output_LCP=output vector
##Output_Cost_Surface=output raster
##Output_Accum_Cost_Surface=output raster
##showplots
setwd(Output)
library(tcltk)
library(sp)
library(movecost)
library(GmAMisc)
library(raster)
library(rgdal)
DTM<-raster(DTM)
if(Function==0)
Function=c("t")
if(Function==1)
Function=c("tofp")
if(Function==2)
Function=c("mp")
if(Function==3)
Function=c("icmonp")
if(Function==4)
Function=c("icmoffp")
if(Function==5)
Function=c("icfonp")
if(Function==6)
Function=c("ug")
if(Function==7)
Function=c("alb")
if(Function==8)
Function=c("gkrs")
if(Function==9)
Function=c("r")
if(Function==10)
Function=c("ree")
if(Function==11)
Function=c("hrz")
if(Function==12)
Function=c("wcs")
if(Function==13)
Function=c("p")
if(Function==14)
Function=c("vl")
if(Function==15)
Function=c("ls")
if(Function==16)
Function=c("b")
if(Function==17)
Function=c("icfoffp")
if(Time==0)
Time=c("h")
if(Time==1)
Time=c("m")
if(Outp==0)
Outp=c("r")
if(Outp==1)
Outp=c("c")
if(Return_Base==0)
Return_Base=c(TRUE)
if(Return_Base==1)
Return_Base=c(FALSE)
if(Cognitive_Slope==0)
Cognitive_Slopee=c(TRUE)
if(Cognitive_Slope==1)
Cognitive_Slope=c(FALSE)
if(CL==0)
CL=c(TRUE)
if(CL==1)
CL=c(FALSE)
if(DL==0)
DL=c(TRUE)
if(DL==1)
DL=c(FALSE)
result<-movecost(dtm=DTM, origin=Origin, destin=Destination,
funct=Function, time=Time, outp=Outp, move=Move,
breaks=Breaks,return.base=Return_Base, cogn.slp=Cognitive_Slope,
sl.crit=Critical_Slope,W=Walker_Body_Weight,L=Carried_Load_Weight,N=N,V=Speed,z=Zoom_Level,rb.lty=RL,cont.lab=CL,destin.lab=DL,cex.breaks=CB,cex.lcp.lab=CLL,
export=TRUE)
msgBox <- tkmessageBox(title = "Import Vector",
message = "Import vector isolines .shp!", icon =
"info", type = "ok")
Output_Isoline=impShp()
msgBox2 <- tkmessageBox(title = "Import Vector",
message = "Import vector LCPs .shp!", icon = "info",
type = "ok")
Output_LCP=impShp()
msgBox3 <- tkmessageBox(title = "Import Raster",
message = "Import raster cost surface!", icon =
raster1<-impRst()
raster1.sp <- as(raster1, "SpatialPixelsDataFrame") # Converting the
RasterLayer object to a SpatialPixelsDataFrame object
Output_Cost_Surface=raster1.sp
msgBox4 <- tkmessageBox(title = "Import Raster",
message = "Import raster accum cost surface !", icon
= "info", type = "ok")
raster2<-impRst()
raster2.sp <- as(raster2, "SpatialPixelsDataFrame") # Converting the
Output_Accum_Cost_Surface=raster2.sp
If some one has some tricks better, should very approciate.
thanks
E
Il giorno gio 1 lug 2021 alle ore 11:07 Enzo Cocca <enzo.ccc at gmail.com> ha
scritto:
> Hi peoples,
> I have a question:
> In my r script I save (some raster and some vector file) in an a folder.
> Is it a method to load my output into qgis?
> I can't use output vector and output raster for some reason regarding the
> R packages that I use.
> so this one is my script:
> ##Movecost=name
> ##DTM=raster
> ##Move=number 8
> ##Breaks=number 0.5
> ##Cognitive_Slope=selection TRUE;FALSE
> ##N=number 1
> ##Speed=number 1
> ##RL=number 2
> ##CB=number 0.6
> ##CLL=number 0.6
> ##showplots
> setwd(Output)
> library(sp)
> library(movecost)
> library(raster)
> library(rgdal)
> DTM<-raster(DTM)
> if(Function==0)
> Function=c("t")
> if(Function==1)
> Function=c("tofp")
> if(Function==2)
> Function=c("mp")
> if(Function==3)
> if(Function==4)
> if(Function==5)
> if(Function==6)
> Function=c("ug")
> if(Function==7)
> Function=c("alb")
> if(Function==8)
> Function=c("gkrs")
> if(Function==9)
> Function=c("r")
> if(Function==10)
> Function=c("ree")
> if(Function==11)
> Function=c("hrz")
> if(Function==12)
> Function=c("wcs")
> if(Function==13)
> Function=c("p")
> if(Function==14)
> Function=c("vl")
> if(Function==15)
> Function=c("ls")
> if(Function==16)
> Function=c("b")
> if(Function==17)
> if(Time==0)
> Time=c("h")
> if(Time==1)
> Time=c("m")
> if(Outp==0)
> Outp=c("r")
> if(Outp==1)
> Outp=c("c")
> if(Return_Base==0)
> Return_Base=c(TRUE)
> if(Return_Base==1)
> if(CL==0)
> CL=c(TRUE)
> if(CL==1)
> CL=c(FALSE)
> if(DL==0)
> DL=c(TRUE)
> if(DL==1)
> DL=c(FALSE)
> export=TRUE)
> thanks in advance
> E
> Enzo Cocca PhD
> in "Science and Technology for Archaeology and Cultural Heritage"
> ISMEO
> International Association of Mediterranean and Oriental Studies
> mail: enzo.ccc at gmail.com
> cell: +393495087014
Enzo Cocca PhD
ISMEO
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210701/3402abdc/attachment.html>
