[QGIS-Developer] Question on @atlas_featureid
Andreas Neumann
andreas at qgis.org
Thu Jul 8 02:34:37 PDT 2021
HI Jürgen,
Yes - I provided the primary key column
Here is my data source string:
service='edit' authcfg=sogis00 key='t_id' srid=2056 type=Polygon
checkPrimaryKeyUnicity='1'
table="alw_strukturverbesserungen"."projekt_aggregiert_v"
(geometrie_convex_hull) sql=geometrie_bbox IS NOT NULL
@atlas_featureid returns something like an internal "row number" or
similar, but not the column "t_id" as defined in the data source string.
Andreas
On Thu, 8 Jul 2021 at 10:42, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Andreas,
> On Thu, 08. Jul 2021 at 10:30:08 +0200, Andreas Neumann wrote:
> > attribute(@atlas_feature,'pkey_name'), but it is a little more
> complicated
> > than @atlas_featureid - and I'm pretty sure that @atlas_featureid was
> using
> > the pkey column in th past?
> > My data source for the atlas coverage layer is a Postgis View.
> It's probably not using the column you expect for the feature id. Did you
> specify the key column when adding the view?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/08571078/attachment.html>
