[QGIS-Developer] Build failure in master
Werner Macho
werner.macho at gmail.com
Thu Jul 8 05:01:31 PDT 2021
Hi Tim,
Just updated master and also tried to build with no errors whatsoever.
(Using ninja and ccache)
Maybe try a clean build?
regards
Werner
On Thu, Jul 8, 2021 at 1:10 PM Tim Sutton <tim at kartoza.com> wrote:
> Hi All
> Just updated to master and getting a build error:
> Consolidate compiler generated dependencies of target
> python_module_qgis__analysis
> [ 68%] Linking CXX shared module ../output/python/qgis/_analysis.so
> /usr/bin/ld:
> CMakeFiles/python_module_qgis__analysis.dir/analysis/sip_analysispart13.cpp.o:/home/timlinux/dev/cpp/QGIS-QtCreator-Build/python/analysis/sip_analysispart13.cpp:138:
> multiple definition of `sipTypeDef__analysis_QgsAnalysis';
> CMakeFiles/python_module_qgis__analysis.dir/analysis/sip_analysispart12.cpp.o:/home/timlinux/dev/cpp/QGIS-QtCreator-Build/python/analysis/sip_analysispart12.cpp:1812:
> first defined here
> collect2: error: ld returned 1 exit status
> gmake[2]: ***
> [python/CMakeFiles/python_module_qgis__analysis.dir/build.make:1101:
> output/python/qgis/_analysis.so] Error 1
> gmake[1]: *** [CMakeFiles/Makefile2:6919:
> python/CMakeFiles/python_module_qgis__analysis.dir/all] Error 2
> gmake[1]: *** Waiting for unfinished jobs....
> Consolidate compiler generated dependencies of target qgis_gui
> [ 78%] Built target qgis_gui
> gmake: *** [Makefile:166: all] Error 2
> 12:03:00: The process "/usr/bin/cmake" exited with code 2.
> Error while building/deploying project qgis (kit: Qt 5.15.2 (qt5))
> When executing step "Build"
> Is it because of the new exif alg maybe?
> Regards
> Tim
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Tim is a member of the QGIS Project Steering Committee
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/d0fead44/attachment.html>
