[QGIS-Developer] Using environment variables in QGIS.ini
Thomas B rdbath.regiodata at gmail.com
Mon Jul 12 23:08:27 PDT 2021
 Hi Alexandre,
    >>This is some old stuff we wrote at Boundless, I believe it still
applies for QGIS today.
https://boundless-desktop.readthedocs.io/en/latest/system_admins/index.html#for-system-administrators
    >>Both initialisation scripts and global setting file can help you with
what you want to achieve.
The initialisation scripts could be useful. But they don't seem to be
merged into the QGIS repository yet.
regards,
Thomas
Am Mo., 12. Juli 2021 um 10:54 Uhr schrieb Alexandre Neto <
senhor.neto at gmail.com>:
> Hi Bo,
> This is some old stuff we wrote at Boundless, I believe it still applies
> for QGIS today.
> Both initialisation scripts and global setting file can help you with what
> (I should make sure this information is available on docs.qgis.org, but I
> never find the time to do it...)
> Best regards,
> Alexandre Neto
> User Support
> www.qcooperative.net
> A segunda, 12/07/2021, 08:34, Bo Victor Thomsen <
> bo.victor.thomsen at gmail.com> escreveu:
>> Hi Thomas -
>> Your suggestion is actually pretty close to the solution I made -
>>    - Standard installation of QGIS with *standard* .msi package.
>>    - After the QGIS installation and before QGIS is started the user do
>>    a one-time run a Python script from et central network drive -  using the
>>    Python interpreter installed together with QGIS  which:
>>    - Unzip a complete profile  with specific plugins and customized
>>       parameters from a central network based repository. This profile replaces
>>       the standard "default" profile.
>>       - Search/replace a couple of "tokenized" values in QGIS.ini with
>>       actual values based on username
>> The profile and tokenized QGIS.ini is prepared by the GIS administrator
>> The Python script is packaged in a .cmd file which is started by the user.
>> Not a perfect solution, but doable:
>>    - The It department is happy: No work doing specialized installations
>>    - The GIS administrator is happy. It's a one-time piece of work for
>>    each QGIS version to  prepare the profile and tokenize the QGIS.ini
>>    - The user is - somewhat - happy. To finish the installation is
>>    simply to double-click once on a file placed in a "highly visible" location.
>>    - Any subsequent mistakes made by the user (Installation of dodgy
>>    plugins, strange changes in setups ....) is easily repaired by running the
>>    Python script again.
>> Med venlig hilsen / Kind regards
>> Bo Victor Thomsen
>> Den 12-07-2021 kl. 03:14 skrev Thomas Gratier:
>> Hi,
>> I'm not aware QSettings provided by Qt can do it. Your %APPDATA% is not
>> portable as would only work on Windows
>> You can always try generate the QGIS.ini file using a templating system
>> File QGIS.ini.j2 with following content
>> Configuration\MODELS_FOLDER={{APPDATA}}\\QGIS\\QGIS3\\profiles\\default\\processing\\models
>> Configuration\SCRIPTS_FOLDERS={{APPDATA}}\\QGIS\\QGIS3\\profiles\\default\\processing\\scripts
>> File generate_ini.py with following content
>> import os
>> import jinja2
>> templateLoader = jinja2.FileSystemLoader(searchpath="./")
>> templateEnv = jinja2.Environment(loader=templateLoader)
>> TEMPLATE_FILE = "QGIS.ini.j2"
>> template = templateEnv.get_template(TEMPLATE_FILE)
>> mydict = {
>>     "APPDATA": os.environ.get("APPDATA")
>> outputText = template.render(**mydict)
>> with open('QGIS.ini', 'w') as outputfile:
>>     outputfile.write(outputText)
>> Then, to write your QGIS.ini file, do
>> python3 generate_ini.py
>> The possible deal breakers with this approach are:
>> - you depend from jinja2, a third party Python library,
>> - you can't later reuse the mechanism if for instance QGIS changes the
>> QGIS.ini file later on
>> Regards
>> Thomas
>> Le mar. 6 juil. 2021 à 09:18, Bo Victor Thomsen <
>> bo.victor.thomsen at gmail.com> a écrit :
>>> To the list -
>>> Is there a method to use OS (Linux, Windows...) environment variables in
>>> the QGIS.ini setup file ?
>>> I had a number of customers asking for a method to "generalize"
>>> QGIS.ini, so it doesn't contain any "user" specific file and directory
>>> references, i.e
>>> (From qgis.ini)
>>> Configuration\MODELS_FOLDER=*C:\\Users\\Bo Victor
>>> Thomsen\\AppData\\Roaming*
>>> Configuration\SCRIPTS_FOLDERS=*C:\\Users\\Bo Victor
>>> could be:
>>> Configuration\MODELS_FOLDER=*%APPDATA%*
>>> Configuration\SCRIPTS_FOLDERS=*%APPDATA%*
>>> or likewise.
>>> The ultimate reason is to have a method to distribute a "standard" setup
>>> for QGIS, complete with plugins and specialized setup parameters. This can
>>> be done by making a standard QGIS installation (which the IT departments
>>> love, especially with the new .msi package) and afterwards replace the
>>> "default" profile directory with at  directory specific for the
>>> organisation. However, the process of making the new profile will place a
>>> lot of file/directory references in QGIS.ini that is specific for the
>>> super-user developing the new profile.
>>> Bo Victor Thomsen
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210713/41e3be01/attachment-0001.html>
More information about the QGIS-Developer mailing list
