[QGIS-Developer] Bug with GeoPackage and Expressions?
Even Rouault
even.rouault at spatialys.com
Wed Jul 28 13:00:12 PDT 2021
SQLite, which is the underneath database engine for GeoPackage, doesn't
support ILIKE. The SQLite LIKE operator is actually case insensitive for
ASCII characters. See paragraph 5 "The LIKE, GLOB, REGEXP, and MATCH
operators" of https://www.sqlite.org/lang_expr.html
Le 28/07/2021 à 21:43, C Hamilton a écrit :
> I think I found a bug and was wondering if someone could verify this.
> I am on Windows 10 and tried this with both QGIS 3.16.9 and 3.20.1.
> I tried the following filter expression on the Natural Earth data set
> ne_10m_populated_places
> (https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_places.zip
> <https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/10m/cultural/ne_10m_populated_places.zip>).
> Once loaded into QGIS right mouse click on the layer and select
> "Properties...", then click on the "Source" tab, click on "Query
> Builder" and then use this query
> "NAME" ILIKE '%Bom%'
> This works fine. If I export ne_10m_populated_places as a GeoPackage
> and try the same thing with the GeoPackage version of the layer, I get
> the error:
> "An error occurred when executing the query, please check the
> expression syntax."
> If I use LIKE instead of ILIKE then it works. It is like ILIKE was not
> implemented for GeoPackage. Can anyone verify this? I think you can
> use any vector layer for this test with one that is a shapefile and
> the other a GeoPackage.
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210728/b296dc4c/attachment.html>
