[QGIS-Developer] QGIS Server Tiles API Plugin
Tim Sutton
tim at kartoza.com
Fri Jul 30 07:00:22 PDT 2021
Oh yay and thank goodness we long miss this! Some questions:
- metabufferring
- metatiling
- tile caching
- tile seeding
Are any of those in your todo list?
Thanks so much for working on this!
Regards
Tim
Sent from my iPhone
> On 30 Jul 2021, at 14:29, Alessandro Pasotti <apasotti at gmail.com> wrote:
> Hi René-Luc,
> This is great news - I was almost sure you would have picked this up :)
> I think you should be able to use most of the OGC API foundation classes that I've written for OAPIF/WFS3.
> Kind Regards.
>> On Fri, Jul 30, 2021 at 12:27 PM René-Luc Dhont <rldhont at gmail.com> wrote:
>> Hi Devs,
>> On request from Ifremer, we at 3Liz are started to work on a plugin to provide Tiles API for QGIS Server.
>> https://github.com/3liz/qgis-server-tiles-plugin
>> We have started to implement a Tile Map Service API, known as TMS.
>> It is based on the QGIS project WMTS configuration availabe in the OWS Server tab in Project properties.
>> If the EPSG:3857 is activated for WMTS, the tiles will be available through a simple URL with the MAP parameter.
>> The TMS API supports images, provided by WMTS, and Vector Tile based on QgsVectorTileWriter.
>> I have discovered that QgsVectorTileMVTEncoder is not available in Python.
>> We have planed to:
>> * implement in this plugin the OGC Tiles API, https://ogcapi.ogc.org/tiles/
>> * enhance the QGIS API to be able to build Vector Tile in other CRS than EPSG:3857
>> * and port the OGC Tiles API in the QGIS Server core.
>> Feedbacks are welcome
>> Regards,
>> René-Luc D'Hont
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210730/1a2fcc60/attachment.html>
