[QGIS-Developer] Offset lines via qgis python
Prem Kumar
prem.netgis at gmail.com
Wed Jun 9 01:41:16 PDT 2021
Hi Ujaval,
Thank you very much for pointing that out. That serves my purpose.
In fact, I had initially searched for a python implementation of the
Offsetlines processing tool but did not get it. Just a quick question, how
do we trace whether the processing tool implementation is in python or c++?
-Prem
On Wed, Jun 9, 2021 at 1:53 PM Ujaval Gandhi <ujaval at spatialthoughts.com>
wrote:
> You can look at the implementation
> <https://github.com/qgis/QGIS/blob/2d1aa68f0d044f2aced7ebeca8d2fa6b754ac970/src/analysis/processing/qgsalgorithmoffsetlines.cpp>
> of offsetline algorithm and you'll notice that it
> uses geometry.offsetCurve(). You can do the same in your code.
> [image: Logo] <https://spatialthoughts.com/>
> Ujaval Gandhi
> Spatial Thoughts
> mobile: +91-8095684687
> email: ujaval at spatialthoughts.com
> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
> Twitter icon] <https://twitter.com/spatialthoughts>
> On Wed, Jun 9, 2021 at 1:31 PM Prem Kumar <prem.netgis at gmail.com> wrote:
>> Hi Team,
>> Just wondering if there is a python api which gets an offset line or
>> parallel line (to both left and right sides) to a given line geometry in
>> Qgis Python. I know there exists a processing tool called Offsetlines
>> <https://docs.qgis.org/3.16/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#offset-lines> but
>> need this similar functionality at geometry object level so that I can
>> create offset lines only when needed based on my logic.
>> The only way now is that I can perform the Offset lines on the entire
>> layer and then access the offset geometry if needed.
>> On other hand, shapely has parallel_offset
>> <https://shapely.readthedocs.io/en/stable/manual.html#object.parallel_offset> but
>> this needs conversion from shapely geometry to qgisgeometry.
>> Just looking for thoughts on this to optimize heavy geometry operations.
>> Appreciate your help.
>> -Prem
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210609/3fc8897e/attachment.html>
