[QGIS-Developer] PyQt issue when building QGIS with python
Tudor Bărăscu
tudorbarascu at yahoo.com
Wed Jun 23 13:19:26 PDT 2021
I think I had the same error thtese last few days, fixed it with apy install python3-pyqt5.qtpositioning on debian.
All the best,
Tudor
Sent from my iPhone
> On 23 Jun 2021, at 22:42, Vincent Cloarec <vcloarec at gmail.com> wrote:
> Hi all,
> Since few days, it is not possible for me to build QGIS with python binding. I've got this error and many others like this:
> FAILED: python/plugins/db_manager/ui_DlgExportVector.py
> cd /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager && /home/vincent/dev/sources/QGIS/scripts/pyuic_wrapper.sh /usr/bin/pyuic5 /home/vincent/dev/building/build-QGIS-Debug/output/lib /home/vincent/dev/building/build-QGIS-Debug/output/python /usr/bin/python3.8 /home/vincent/dev/sources/QGIS/python/plugins/db_manager/ui/DlgExportVector.ui -o /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager/ui_DlgExportVector.py
> An unexpected error occurred.
> Check that you are using the latest version of PyQt5 and send an error report to
> support at riverbankcomputing.com, including the following information:
> * your version of PyQt (5.14.1)
> * the UI file that caused this error
> * the debug output of pyuic5 (use the -d flag when calling pyuic5)
> Any direction I can explore ?
> Thanks
> Vincent
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210623/beb690b3/attachment.html>
