[QGIS-Developer] OSGeo4W v2 Network Installer QGIS/GRASS issue
    Giuseppe Baiamonte
    gbaiamonte at gmail.com
    Thu Jun 24 09:29:09 PDT 2021
new package versions (3.16.8-2 and 3.20.0-2) fixed the problem with
GRASS not working in QGIS.
The issue is also discussed here https://github.com/qgis/QGIS/issues/43844
(closed)
Thanks everyone for the quick fix!
Best,
Giuseppe
Il giorno gio 24 giu 2021 alle ore 17:57 Andrea Giudiceandrea <
andreaerdna at libero.it> ha scritto:
> Giuseppe Baiamonte wrote Tue Jun 22 06:51:57 PDT 2021
> After performing a fresh installation of QGIS on a PC running Windows 10
> Pro using the new OSGeo4W v2 Network Installer:
> - GRASS 7.8.5 is correctly installed but not working in QGIS;
> - qgis-grass-plugin is installed but not working in QGIS;
> - qgis-grass-plugin7 is not available in the installer;
> - No shortcut(s) "with GRASS" created.
> - qgis-bin-g7.exe is not present in the installation directory.
> Hi Giuseppe,
> new packages versions are now available in the OSGeo4W v2 repository.
> If GRASS in QGIS still doesn't work with the new packages versions, I
> think you can also report the issue opening a "ticket" on
> https://trac.osgeo.org/osgeo4w/
> Best regards.
> Andrea
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/8b4f7594/attachment-0001.html>
