[QGIS-Developer] Custom processing script instabilities
Luigi Pirelli
luipir at gmail.com
Thu Jun 24 13:34:01 PDT 2021
hard to say something without reading the code... btw generally you do not
have to interact with main GUi from a processing alg that by default run in
a separated thread => this can cause crash if you do not use standard
processing libs (e.g. feedback) to send message to the user.
No idea if this could be the source of the problem., IMHO sharing the code
would help and also help to verify if it can be replicable.
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Thu, 24 Jun 2021 at 21:51, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> Greetings,
> I have one custom script that uses PIL to get the exif tag, and when I
> execute the script for the first time, the processing window vanishes and
> qgis stall and then crashes.
> To get it to run properly I had to set the return before opening the files
> with PIL to run a neutered version and then subsequent runs were flawless
> during that qgis instance.
> I ended up using a standalone exif reader, though slower , but there are
> no more crashes.
> Has anyone else had similar issues and is anyone aware of a way to prevent
> such crashes or handle them more gracefully, as no trace is left currently.
> Thanks and have a nice day,
> Alex
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/084a8256/attachment.html>
