[QGIS-Developer] Reg: native:clip processing tool error with "Could not create memory layer"
Prem Kumar prem.netgis at gmail.com
Fri Jun 25 04:55:16 PDT 2021
Hi Team,
I am trying to run a script which initially clips certain data and then
outputs an in-memory clipped layer that will be used further in the code on
the linux machine.
The script used to work perfectly fine on both Windows and Linux machines,
however, only linux machines below errors are seen off late saying output
in-memory layer is not created. Suspected disk space availability issue but
it is not. Any thoughts to troubleshoot would be appreciated. Thanks.
[image: image.png]
Regards,
Prem
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210625/d15f0ce2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210625/d15f0ce2/attachment-0001.png>
More information about the QGIS-Developer mailing list
