[QGIS-Developer] Custom processing script instabilities
Nyall Dawson
nyall.dawson at gmail.com
Fri Jun 25 23:49:35 PDT 2021
On Fri, 25 Jun 2021 at 05:51, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> Greetings,
> I have one custom script that uses PIL to get the exif tag, and when I execute the script for the first time, the processing window vanishes and qgis stall and then crashes.
> To get it to run properly I had to set the return before opening the files with PIL to run a neutered version and then subsequent runs were flawless during that qgis instance.
> I ended up using a standalone exif reader, though slower , but there are no more crashes.
You can use the GDAL python library and retrieve exif metadata via a
call to GDALGetMetadata. This has the benefit of being available
EVERYWHERE qgis is available, with no added dependencies!
Nyall
> Has anyone else had similar issues and is anyone aware of a way to prevent such crashes or handle them more gracefully, as no trace is left currently.
> Thanks and have a nice day,
> Alex
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
