[QGIS-Developer] Reg: native:clip processing tool error with "Could not create memory layer"
Prem Kumar prem.netgis at gmail.com
Mon Jun 28 10:13:08 PDT 2021
Hi Nyall,
In the process of isolating the issue to reproduce the problem with a small
piece of code, I could find the root cause being unable to pick the
postgres database driver. I have changed the prefix path on linux while
creating the qgsApplication and started working.
Thanks for your help.
-Prem
On Sat, Jun 26, 2021 at 12:20 PM Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On Fri, 25 Jun 2021 at 21:56, Prem Kumar <prem.netgis at gmail.com> wrote:
> > Hi Team,
> > I am trying to run a script which initially clips certain data and then
> outputs an in-memory clipped layer that will be used further in the code on
> the linux machine.
> > The script used to work perfectly fine on both Windows and Linux
> machines, however, only linux machines below errors are seen off late
> saying output in-memory layer is not created. Suspected disk space
> availability issue but it is not. Any thoughts to troubleshoot would be
> appreciated. Thanks.
> You'll need to share your script for any meaningful replies. Are you
> able to do this?
> Nyall
> > Regards,
> > Prem
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210628/f289574c/attachment.html>
More information about the QGIS-Developer mailing list
