[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Hernán De Angelis
variablestarlight at gmail.com
Tue Mar 2 01:53:48 PST 2021
On 2021-03-02 10:45, Richard Duivenvoorde wrote:
> On 3/2/21 9:51 AM, Hernán De Angelis wrote:
>> On 2021-03-02 09:48, Alexandre Neto wrote:
>>> Might seem obvious, but have you tried using a brand new profile?
>> Yes, I just forgot to add that to the description below.
> Or even a new profiles_path ?
> $ qgis --help
> QGIS is a user friendly Open Source Geographic Information System.
> Usage: qgis [OPTION] [FILE]
> OPTION:
> [--version] display version information and exit
> [--snapshot filename] emit snapshot of loaded datasets to given file
> [--width width] width of snapshot to emit
> [--height height] height of snapshot to emit
> [--lang language] use language for interface text (changes existing override)
> [--project projectfile] load the given QGIS project
> [--extent xmin,ymin,xmax,ymax] set initial map extent
> [--nologo] hide splash screen
> [--noversioncheck] don't check for new version of QGIS at startup
> [--noplugins] don't restore plugins on startup
> [--nocustomization] don't apply GUI customization
> [--customizationfile path] use the given ini file as GUI customization
> [--globalsettingsfile path] use the given ini file as Global Settings (defaults)
> [--authdbdirectory path] use the given directory for authentication database
> [--code path] run the given python file on load
> [--defaultui] start by resetting user ui settings to default
> [--hide-browser] hide the browser widget
> [--dxf-export filename.dxf] emit dxf output of loaded datasets to given file
> [--dxf-extent xmin,ymin,xmax,ymax] set extent to export to dxf
> [--dxf-symbology-mode none|symbollayer|feature] symbology mode for dxf output
> [--dxf-scale-denom scale] scale for dxf output
> [--dxf-encoding encoding] encoding to use for dxf output
> [--dxf-map-theme maptheme] map theme to use for dxf output
> [--take-screenshots output_path] take screen shots for the user documentation
> [--screenshots-categories categories] specify the categories of screenshot to be used (see QgsAppScreenShots::Categories).
> [--profile name] load a named profile from the users profiles folder.
> [--profiles-path path] path to store user profile folders. Will create profiles inside a {path}\profiles folder
> [--version-migration] force the settings migration from older version if found
> [--openclprogramfolder] path to the folder containing the sources for OpenCL programs.
> [--help] this text
> [--] treat all following arguments as FILEs
> So:
> qgis --profiles-name /tmp/superclean
> I would not know if this would help... but just in case
Thanks you Richard, but that did not work either.
Thanks Alexander and Nyall too.
This is happening in a fresh install (one month old) of openSUSE
Tumbleweed in a new machine. No older profiles to blame here. Also I did
delete the profiles many times.
No clue by now, will have to keep looking.
Thanks again everyone
Hernán
