[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Hernán De Angelis variablestarlight at gmail.com
Tue Mar 2 23:55:42 PST 2021
On 2021-03-03 00:10, Tim Sutton wrote:
> Hi
> Can you check if you have python-psycopg2 installed on your system? I
> had a similar issue a month or two back which was fixed by installing
> it. (Thanks for the nudge Nyall).
YES! That was the problem!
Now I have all the tools, including GRASS and GDAL, and Voronoi of course.
Thank you!
Hernán
> Regards
> Tim
> On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis
> <variablestarlight at gmail.com <mailto:variablestarlight at gmail.com>> wrote:
>     On 2021-03-02 10:51, Richard Duivenvoorde wrote:
>     > On 3/2/21 10:41 AM, Hernán De Angelis wrote:
>     >> On 2021-03-02 10:21, Nyall Dawson wrote:
>     >>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
>     >>>> Hi,
>     >>>> I wrote about this a few days ago in the user list but I
>     still have the
>     >>>> problem and can find neither a cause nor a solution. I thus
>     post it in
>     >>>> this list in the hope that some developer may have a hint on
>     what is
>     >>>> going wrong here.
>     >>> Double check that you have the gdal python packages installed
>     >> Thanks for this,
>     >> from osgeo import gdal
>     >> just works, so I guess it is installed.
>     > What is the value of
>     > BINDINGS_GLOBAL_INSTALL
>     > in your compile config?
>     The value is "YES"
>     > Looks like something is not picked up with your install.
>     Agree
>     > What if you run qgis 31.8 from the 'output/bin' dir in your
>     build directory?
>     Behaves just the same
>     > If all fails I would (I think) compile and set
>     CMAKE_INSTALL_PREFIX in some local dir in your HOME
>     > I did in ~/bin/qgis_/3.18/debug (for debug build):
>     > And create a startup script like
>     > export
>     LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
>     > export
>     PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
>     > export QGIS_DEBUG=0
>     > # passing ALL parameters to qgis bin
>     > # eg to be able to call a certain translation
>     > # qgis --lang nl
>     > ~/bin/qgis_/3.18/debug/bin/qgis "$@"
>     Thanks, will think about this and try it.
>     Thank you again for your ansers. I see I have a sort of
>     linking/library
>     problem. GRASS is installed and GRASS modules are compiled but then
>     these do not appear either in the menu.
>     /Hernán
>     > Suc6
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe:
> Tim Sutton
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210303/33d01368/attachment.html>
More information about the QGIS-Developer mailing list
