[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
    Hernán De Angelis
    variablestarlight at gmail.com
    Tue Mar  2 23:57:57 PST 2021
On 2021-03-03 00:12, Nyall Dawson wrote:
> On Wed, 3 Mar 2021 at 09:10, Tim Sutton <tim at kartoza.com> wrote:
>> Hi
>> Can you check if you have python-psycopg2 installed on your system? I had a similar issue a month or two back which was fixed by installing it. (Thanks for the nudge Nyall).
> Ah -- that was the one!  I thought it was gdal for some reason...
> flaky memory :)
> We should really investigate why this caused a silent failure to show
> the algorithms instead of an error...
Yes, an error message could be beneficial. I remember from previous
installations that QGIS would complain on opening that psycopg (or other
python modules) weren't installed.
/H.
> Nyall
>> Regards
>> Tim
>> On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis <variablestarlight at gmail.com> wrote:
>>> On 2021-03-02 10:51, Richard Duivenvoorde wrote:
>>>> On 3/2/21 10:41 AM, Hernán De Angelis wrote:
>>>>> On 2021-03-02 10:21, Nyall Dawson wrote:
>>>>>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
>>>>>>> Hi,
>>>>>>> I wrote about this a few days ago in the user list but I still have the
>>>>>>> problem and can find neither a cause nor a solution. I thus post it in
>>>>>>> this list in the hope that some developer may have a hint on what is
>>>>>>> going wrong here.
>>>>>> Double check that you have the gdal python packages installed
>>>>> Thanks for this,
>>>>> from osgeo import gdal
>>>>> just works, so I guess it is installed.
>>>> What is the value of
>>>> BINDINGS_GLOBAL_INSTALL
>>>> in your compile config?
>>> The value is "YES"
>>>> Looks like something is not picked up with your install.
>>> Agree
>>>> What if you run qgis 31.8 from the 'output/bin' dir in your build directory?
>>> Behaves just the same
>>>> If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX in some local dir in your HOME
>>>> I did in ~/bin/qgis_/3.18/debug (for debug build):
>>>> And create a startup script like
>>>> export LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
>>>> export PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
>>>> export QGIS_DEBUG=0
>>>> # passing ALL parameters to qgis bin
>>>> # eg to be able to call a certain translation
>>>> # qgis --lang nl
>>>> ~/bin/qgis_/3.18/debug/bin/qgis "$@"
>>> Thanks, will think about this and try it.
>>> Thank you again for your ansers. I see I have a sort of linking/library
>>> problem. GRASS is installed and GRASS modules are compiled but then
>>> these do not appear either in the menu.
>>> /Hernán
>>>> Suc6
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton
>> Visit http://kartoza.com to find out about open source:
>>   * Desktop GIS programming services
>>   * Geospatial web development
>> * GIS Training
>> * Consulting Services
>> Tim is a member of the QGIS Project Steering Committee
