[QGIS-Developer] WITH_PDAL and WITH_EPT doubt
Alexandre Neto senhor.neto at gmail.com
Sat Mar 6 02:33:11 PST 2021
Sorry for the basic questions, I was about to say. I am lagging a bit on
all this point cloud business, but I wanted to make it available on
conda-forge.
Thanks,
Alexandre Neto
A sábado, 6/03/2021, 09:53, Alexandre Neto <senhor.neto at gmail.com> escreveu:
> Hi Sylvain,
> Thank you for you answer. Yes, the build in conda is building untwine for
> sure. I know because the windows build is failing there. So that's a result
> of with_ept=true?
>  entwine or untwine serve the same purpose? Is there a prefered one?
> If I build using WITH_EPT = true, does it make sense to install entwine
> (from packaging system) anyway? Or, in that case, I should use WITH_EPT =
> FALSE?
> Sorry for
> A sábado, 6/03/2021, 09:28, Sylvain POULAIN <sylvain.poulain at giscan.com>
> escreveu:
>> Hi Alexandre,
>> When you build qgis with cmake, it will build untwine (not entwine) in
>> qgis structure.
>> I guess it could be the same with conda but not tested.
>> Regards,
>> *Sylvain*
>> Le mer. 3 mars 2021 à 12:46, Alexandre Neto <senhor.neto at gmail.com> a
>> écrit :
>>> Hello again,
>>> Does this mean that, if entwine isn't present in the system, the
>>> compilation won't fail or complaint, but some functionality will be missing?
>>> Should I include entwine as a dependency for 3.18.0 on conda-forge?
>>> Thanks,
>>> Alexandre
>>> A quarta, 3/03/2021, 03:40, Alexandre Neto <senhor.neto at gmail.com>
>>> escreveu:
>>>> Great, thanks!
>>>> A quarta, 3/03/2021, 02:03, Nyall Dawson <nyall.dawson at gmail.com>
>>>> escreveu:
>>>>> On Wed, 3 Mar 2021 at 11:59, Alexandre Neto <senhor.neto at gmail.com>
>>>>> wrote:
>>>>> > Hi,
>>>>> > I am trying to add point cloud support to QGIS on conda-forge [0],
>>>>> but I am unsure if I need to use
>>>>> > WITH_PDAL=TRUE
>>>>> yes, you'll need to add this even if you have pdal library available.
>>>>> it defaults to false to avoid breaking the compilation if pdal isn't
>>>>> available (and we want explicit breaks here rather than silently
>>>>> compiling without pdal provider if the library isn't found).
>>>>> > and WITH_EPT=TRUE
>>>>> That defaults to true anyway, so you can omit it if you want.
>>>>> Nyall
>>>> _______________________________________________
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210306/1027672b/attachment.html>
More information about the QGIS-Developer mailing list
