[QGIS-Developer] REST API for QGIS processing tool
Prem Kumar prem.netgis at gmail.com
Tue Mar 23 12:47:23 PDT 2021
Hi David,
While installing the service from source code files using given
instructions, further details of the exception I have encountered.
[image: image.png]
 Complete output from command python setup.py egg_info:
    ERROR: Minimum supported PROJ version is 7.2.0, installed version is
4.9.3. For more information see: https://pyproj4.github.io/py
 proj/stable/installation.html
Command "python setup.py egg_info" failed with error code 1 in
/tmp/pip-build-qejkjny8/pyproj/
[image: image.png]
After several attempts of troubleshooting, I could bypass this issue
with "*pip3
install pyproj==1.9.6 -e ." * ..... not sure this is the correct way or
not. However, after installation from source files directory, I could not
either run the runwps.sh
<https://github.com/3liz/py-qgis-wps/blob/master/runwps.sh> file or
*wpsserver *from command line as the terminal unable to recognize wpsserver
command.
*./runwps.sh: line 15: exec: wpsserver: not found*
Please suggest. Thanks.
-Prem
On Mon, Mar 22, 2021 at 11:19 PM David Marteau <dmarteau at 3liz.com> wrote:
> Le 22/03/2021 à 18:26, Prem Kumar a écrit :
> Hi Team,
> Im afraid to make a comment but the installation instructions in the
> github are not specifically referring the integration of service and the
> qgis installation and its modules. I have tried installing py-qgs-wps on
> linux machine using archive tar file and ended up incompatibility issue
> between python version - qgis installation and the service.
> If it’s not more of an effort, can you please guide me to any installation
> instructions? Thanks
> Can you be more specific about the error your are facing ? if that's about
> py-qgs-wps then you should open an issue on github.
> -Prem
> On Thu, 25 Feb 2021 at 7:44 PM, Prem Kumar <prem.netgis at gmail.com> wrote:
>> HI Nyall and René-Luc,
>> Thank you very much for the pointers, much appreciated. Looks to me, a
>> lot to learn some good stuff. Will let you know how it goes.
>> -Prem
>> On Thu, Feb 25, 2021 at 6:59 PM René-Luc Dhont <rldhont at gmail.com> wrote:
>>> Le 24/02/2021 à 23:27, Nyall Dawson a écrit :
>>> > Look into the "WPS" standard. There's even an existing server for
>>> > this: https://github.com/3liz/py-qgis-wps
>>> Thanks Nyall to pointing it.
>>> Prem, If you are interested in a REST API, implementing the OGC API
>>> Processes standard is  being considered for py-qgis-wps
>>> * https://github.com/opengeospatial/ogcapi-processes/
>>> * https://ogcapi.ogc.org/processes/
>>> py-qgis-wps is based on Tornado and any contributions are welcome.
>>> René-Luc
>>> > Nyall
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210324/8337ca0e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210324/8337ca0e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210324/8337ca0e/attachment-0003.png>
More information about the QGIS-Developer mailing list
