[QGIS-Developer] Fwd: Re: QGIS Docs: ReStructureText flavour?
Jonathan Moules jonathan-lists at lightpear.com
Wed Mar 31 05:54:43 PDT 2021
Thanks Rosa!
Both yes and no.
That does have the spec (though no reference to the "only::" thing), but
it doesn't say what parser to use for it.
I see that the :ref: thing is pulled from python
(https://devguide.python.org/documenting/#cross-linking-markup) but
again, the parsers I've been trying are barfing on that (and one is a
Python IDE!) meaning I can't actually reliably preview an RST which I
imagine reduces contributions (I've lost an hour to this so far!).
A more general question to the community would be: Wouldn't it make more
sense to use plain RST to allow the largest toolset possible to edit the
docs?
Thanks again,
Jonathan
On 2021-03-31 13:28, l wrote:
> Hey.
> Is this what you are looking for:
> https://docs.qgis.org/testing/en/docs/documentation_guidelines/writing.html#writing-documentation?
> Best,
> Rosa
> MSc Rosa Aguilar - PhD Candidate
> University of Twente
> Faculty of Geoinformation Science and Earth Observation
> Connect with me on LinkedIn
> https://rosaguilar.github.io
> The essential is invisible to the eye. Saint-Exupéry
> -----Original Message-----
> From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On
> Behalf Of Jonathan Moules
> Sent: 31 March 2021 14:21
> To: QGIS Developer Mailing List <qgis-developer at lists.osgeo.org>
> Subject: [QGIS-Developer] QGIS Docs: ReStructureText flavour?
> Hi List,
> What flavour is the RST behind the QGIS docs? There are quite a few
> things in here that are syntax erroring all the parsers I'm trying and
> aren't in the basic RST spec either
> (https://docutils.sourceforge.io/docs/user/rst/cheatsheet.txt).
> For example using ":ref:" for internal hyperlinks when the spec says
> they should be done like this:
> https://docutils.sourceforge.io/docs/user/rst/quickref.html#internal-hyperlink-targets
> (there is no "ref" in the specs). Or the `.. only:: html` that starts
> some files.
> I tried looking at the QGIS Docs page but I couldn't see anything
> about what RST standard the docs should be written to. Where can I
> find the spec?
> Cheers,
> Jonathan
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
