[QGIS-Developer] QGIS Compilation on Windows
Olivier Dalang
olivier.dalang at gmail.com
Wed May 5 07:33:16 PDT 2021
Hi !
Same issue here, but for master
@Jurgen Am I right understanding currently, to build on Windows, one should
ignore INSTALL.txt and rather try to replicate what's being done here :
https://github.com/jef-n/OSGeo4W/blob/master/src/qgis-dev/osgeo4w/package.sh
I tried to fiddle a little bit (such as upgrade cmake due to "Policy
"CMP0094" is not known to this version of CMake" as above), but then ran
into other issues, which are a bit cryptic to me.
Do you have by any chance the updating of the building docs for Windows on
your roadmap ? Or anything additional to that (such as build dependencies
versions ?)
In the meantime, I can build through WSL2, but I'd prefer to be able to
build natively as it's better to manually test.
Thanks !!
Olivier
On Fri, 16 Apr 2021 at 10:49, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi,
> On Thu, 15. Apr 2021 at 17:35:27 -0700, rnathreddy at sanasw.com wrote:
> > As I understand
> > 1) Use the QGIS version 3.16 repository
> > 2) Use Microsoft Visual Studio 2019 compiler
> > 3) Use the up to date Osgeo4w repositories using
> http://download.osgeo.org/osgeo4w/testing/osgeo4w-setup.exe
> Only for master the new repository is required - and in turn the new
> compiler.
> For 3.16 or 3.18 you can stick with what's documented. But you can also
> switch.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210505/7fcb2a23/attachment.html>
