[QGIS-Developer] QgsProcessingFeedback setProgressText method
matteo
matteo.ghetta at gmail.com
Fri May 28 06:14:07 PDT 2021
Hi Nyall,
> I can't answer if it's expected behavior or not.. it's very old code
> which has been ported and moved around a lot over the years.
> But I would suggest that setProgressText isn't that widely used and
> isn't really necessary. If it's a useful message write it direct to
> the log instead.
thanks for the explanation. I also think that using setProgressText
within a loop is time consuming if printing a lot of stuff in the Log Panel.
Cheers
Matteo
