[QGIS-Developer] Reg: QgsCoordinateTransform not working on Linux
Nyall Dawson
nyall.dawson at gmail.com
Sun May 30 18:44:36 PDT 2021
On Fri, 28 May 2021 at 18:15, Prem Kumar <prem.netgis at gmail.com> wrote:
> HI Nyall,
> Although the projinfo command works fine on a windows machine, I'm afraid I could not find projinfo command on my linux machine initially and even after installing PROJ (sudo apt-get install proj-bin). If you can help me on how to get PROJINFO command running on linux, that would be really great (very little troubleshooting options on this issue over the internet ).
Hmm... this is pointing toward something being quite broken with your
setup. What distro are you running?
Nyall
