[QGIS-Developer] QGIS-Documentation fails to build
    Delaz J
    delazj at gmail.com
    Mon May 31 23:23:10 PDT 2021
The doctest is again failing, actually aborted by GitHub after 6 hours
(it used to take <5mn). Began yesterday.
 From what I can see, it's struggling to connect and download to the
qgis docker image. See
https://github.com/qgis/QGIS-Documentation/runs/2715733455?check_suite_focus=true
vs
https://github.com/qgis/QGIS-Documentation/runs/2709502529?check_suite_focus=true
Any help appreciated.
Thanks,
Harrissou
Le 28/05/2021 à 11:03, DelazJ a écrit :
> Hi,
> Thanks Alessandro. Fixed now.
> Harrissou
> Le mer. 26 mai 2021 à 15:48, Alessandro Pasotti <apasotti at gmail.com
> <mailto:apasotti at gmail.com>> a écrit :
>     It has been moved to the parent class QgsMapLayer
>     On Wed, May 26, 2021 at 3:32 PM DelazJ <delazj at gmail.com
>     <mailto:delazj at gmail.com>> wrote:
>         Hi devs,
>         QGIS-Documentation build test is failing due to "WARNING:
>         py:meth reference target not found:
>         qgis.core.QgsVectorLayer.setDataSource" [0]
>         It looks like the QgsVectorLayer.setDataSource method is no
>         longer available in master. Anyone knows what is the replacement?
>         Thanks,
>         Harrissou
>         [0]
>         https://github.com/qgis/QGIS-Documentation/runs/2672228415?check_suite_focus=true#step:5:622
>         <https://github.com/qgis/QGIS-Documentation/runs/2672228415?check_suite_focus=true#step:5:622>
>         _______________________________________________
>         QGIS-Developer mailing list
>         QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>
>         List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>         Unsubscribe:
>     Alessandro Pasotti
>     QCooperative: www.qcooperative.net <https://www.qcooperative.net>
>     ItOpen: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210601/4685950e/attachment.html>
