[QGIS-Developer] QGIS 3.22 compilation on windows 10 with MSVC 2019
Paul N
surveykshak at gmail.com
Mon Nov 1 08:58:09 PDT 2021
Hi, I am trying to compile QGIS 3.22 on Windows 10 using MSVC 2019 and
getting an error after running 'configure.bat'.
E:\Repositories\QGIS-release-3_22\ms-windows\osgeo4w>configonly.bat
usage: msvc-env.bat [x86|x86_64]
sample: msvc-env.bat x86_64
BEGIN: 01-11-2021 20:28:17.18
CMAKE: 01-11-2021 20:28:17.31
CMake Error: Could not create named generator Visual Studio 16 2019 -A x64
Generators
* Visual Studio 16 2019 = Generates Visual Studio 2019 project
files. Use -A option to specify architecture.
Visual Studio 15 2017 [arch] = Generates Visual Studio 2017 project
files. Optional [arch] can be "Win64" or "ARM".
Visual Studio 14 2015 [arch] = Generates Visual Studio 2015 project
Visual Studio 12 2013 [arch] = Generates Visual Studio 2013 project
Visual Studio 11 2012 [arch] = Generates Visual Studio 2012 project
Visual Studio 10 2010 [arch] = Generates Visual Studio 2010 project
files. Optional [arch] can be "Win64" or "IA64".
Visual Studio 9 2008 [arch] = Generates Visual Studio 2008 project
Borland Makefiles = Generates Borland makefiles.
NMake Makefiles = Generates NMake makefiles.
NMake Makefiles JOM = Generates JOM makefiles.
MSYS Makefiles = Generates MSYS makefiles.
MinGW Makefiles = Generates a make file for use
with mingw32-make.
Green Hills MULTI = Generates Green Hills MULTI
files (experimental, work-in-progress).
Unix Makefiles = Generates standard UNIX makefiles.
Ninja = Generates build.ninja files.
Ninja Multi-Config = Generates build-<Config>.ninja files.
Watcom WMake = Generates Watcom WMake makefiles.
CodeBlocks - MinGW Makefiles = Generates CodeBlocks project files.
CodeBlocks - NMake Makefiles = Generates CodeBlocks project files.
CodeBlocks - NMake Makefiles JOM = Generates CodeBlocks project files.
CodeBlocks - Ninja = Generates CodeBlocks project files.
CodeBlocks - Unix Makefiles = Generates CodeBlocks project files.
CodeLite - MinGW Makefiles = Generates CodeLite project files.
CodeLite - NMake Makefiles = Generates CodeLite project files.
CodeLite - Ninja = Generates CodeLite project files.
CodeLite - Unix Makefiles = Generates CodeLite project files.
Eclipse CDT4 - NMake Makefiles = Generates Eclipse CDT 4.0 project files.
Eclipse CDT4 - MinGW Makefiles = Generates Eclipse CDT 4.0 project files.
Eclipse CDT4 - Ninja = Generates Eclipse CDT 4.0 project files.
Eclipse CDT4 - Unix Makefiles= Generates Eclipse CDT 4.0 project files.
Kate - MinGW Makefiles = Generates Kate project files.
Kate - NMake Makefiles = Generates Kate project files.
Kate - Ninja = Generates Kate project files.
Kate - Unix Makefiles = Generates Kate project files.
Sublime Text 2 - MinGW Makefiles = Generates Sublime Text 2 project files.
Sublime Text 2 - NMake Makefiles = Generates Sublime Text 2 project files.
Sublime Text 2 - Ninja = Generates Sublime Text 2 project files.
Sublime Text 2 - Unix Makefiles = Generates Sublime Text 2 project files.
cmake failed
BUILD ERROR 1: 01-11-2021 20:28:17.42
What change I required to make in configure.bat and msvc_env.bat. Help?
Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211101/ea41dd50/attachment.html>
