[QGIS-Developer] array inconsistencies between QGIS and PostgreSQL
Andreas Neumann a.neumann at carto.net
Tue Nov 16 06:48:34 PST 2021
I have a PostgreSQL table with columns of type array (like int4[4] or
text[]).
Now I have issues in QGIS when trying to save a QGIS array to this
PostgreSQL array.
Arrays in QGIS use a square bracket notation, array in PostgreSQL use a
curly braces notation.
Now if I try to save a QGIS array (result of an expression) to this
PostgreSQL array column, it fails.
If I formulate the expression such, that the array starts/ends with
curly braces, I can save the array in PostgreSQL, but it wouldn't load
in the "list" widget, which is supposed to work with an array. The
documentation claims "List: Displays a single column table to add
different values within a single field. This is currently supported by
the PostgreSQL provider, for fields of array type." (from
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#edit-widgets
Does someone know how I can properly populate a "list widget" with an
array, or at least make the array work properly with at "Text" widget?
The latter would also be acceptable, but the list widget would be nicer.
Here is what I tried:
overlay_intersects(layer:='AV Gemeindegrenze', expression:=bfs_nr)
  --> returns, f.e. [2555,2554] as a QGIS array
and
'{' || array_to_string(overlay_intersects(layer:='AV Gemeindegrenze',
expression:=bfs_nr)) || '}'
--> returns, f.e. {2555,2554} as a string
Neither way works properly. The latter way let's me at least save the
data in PostgreSQL, but it wouldn't display correctly in QGIS (tried
LIST and Text widget).
Thank you for your help!
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211116/afb00d33/attachment.html>
More information about the QGIS-Developer mailing list
