[QGIS-Developer] Purpose and function of "referenced_columns" in Python expression functions?
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Nov 22 05:41:07 PST 2021
Hi list,
https://docs.qgis.org/3.22/en/docs/user_manual/expressions/expression.html#function-editor
mentions the optional keyword argument "referenced_columns" to the
`@qgsfunction` decorator. It says
> referenced_columns=[list]: An array of attribute names that are
required to the function. Defaults to
> [QgsFeatureRequest.ALL_ATTRIBUTES].
That, and examples where it is used in other people's code, led me to
believe that the feature's attributes would not be accessible unless
listed in that parameter or if the parameter was omitted (-> default
value getting used -> default is all attributes).
The default code that gets inserted into the editor includes the
decorator `@qgsfunction(args='auto', group='Custom',
referenced_columns=[])` so I'd assume that I would not be able to use
any attributes in the function.
In reality I can access them just fine though, e. g. `feature["name"]`
if I had features with a "name" attribute and that default
`referenced_columns=[]`.
I can even do so if I used `referenced_columns=["foo", "bar"]`!
`feature["name"]` is still perfectly accessible.
Is this a bug or by design? If by design, what purpose does this
parameter have?
Thanks
Hannes
Johannes Kröger / GIS-Entwickler/-Berater
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Where2B Konferenz 2021
16. Dezember 2021
im Universitätsclub Bonn und online
https://where2b-conference.com/
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211122/3af557ce/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211122/3af557ce/attachment-0001.sig>
