[QGIS-Developer] Unabbreviated expression evaluation preview?
Andreas Neumann
andreas at qgis.org
Mon Nov 22 06:14:20 PST 2021
Agreed - I also like the "Copy to Clipboard" idea.
Andreas
On Mon, 22 Nov 2021 at 14:45, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Hannes,
> Good request.
> I think it's mainly the way it is for not cluttering the - already heavy -
> interface too much. And potential performance problems if someone tries to
> put the complete qgis source code into the preview (... that might lead to
> other problems too ...)
> I'd propose an on-demand popup and integrate a "copy to clipboard" action
> at the same time.
> That would justify a feature request on github.
> Cheers
> Matthias
> On Mon, Nov 22, 2021 at 2:26 PM Johannes Kröger (WhereGroup) <
> johannes.kroeger at wheregroup.com> wrote:
>> Hi list,
>> when developing QGIS expression the preview string output of the
>> evaluation at the bottom of the dialog (e. g. Field Calculator) is super
>> helpful. But it gets cut off after ~60 characters so for longer returns
>> you cannot see them fully.
>> Is there an important reason for that cutoff or would it theoretically
>> be possible to display the whole return value (e. g. in a scrollable
>> area if needed)? Maybe that would require a safety limit at a couple of
>> thousand characters but it would allow for more insight.
>> Cheers
>> Hannes
>> Johannes Kröger / GIS-Entwickler/-Berater
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Tel: +49 (0)228 / 90 90 38 - 36
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
>> Where2B Konferenz 2021
>> 16. Dezember 2021
>> im Universitätsclub Bonn und online
>> https://where2b-conference.com/
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211122/d2b3b203/attachment.html>
