[QGIS-Developer] py3_env bat file on osgeo4w install?
Alexandre Neto
senhor.neto at gmail.com
Tue Nov 30 18:29:18 PST 2021
Nyall, you are right. that is no longer needed.
Moreover, I was wrongly expecting that that py3_env.bat also set up
PYTHONPATH to include the %OSGEO_ROOT%apps/qgis/python folder, which never
was the case even in osgeo4w v1
Thanks,
Alexandre
On Wed, Dec 1, 2021 at 12:33 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 1 Dec 2021 at 10:30, Alexandre Neto <senhor.neto at gmail.com> wrote:
> > Hi,
> > For windows users, there used to be a bat file called py3_env.bat that
> would set up the necessary path variables so that python scripts can find
> QGIS packages.
> > With the OSGeo V2 V2 installer, I can't seem to find it.
> > Am I missing something?
> I believe it's no longer required, because osgeo v2 ONLY has python 3
> (no python 2).
> Nyall
> > Thanks,
> > Alexandre Neto
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211201/77fc4e4c/attachment.html>
