[QGIS-Developer] Fail compiing WITH_3D on ubuntu 20.04 - Qt53DExtras config files missing
Alexandre Neto senhor.neto at gmail.com
Mon Oct 4 06:04:31 PDT 2021
It worked!
Thanks Denis
On Mon, Oct 4, 2021 at 1:09 PM Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> I believe you have to set this on 20.04
> -DQT5_3DEXTRA_LIBRARY=/usr/lib/x86_64-linux-gnu/libQt53DExtras.so
> -DQT5_3DEXTRA_INCLUDE_DIR=/root/QGIS/external/qt3dextra-headers
> -DCMAKE_PREFIX_PATH=/root/QGIS/external/qt3dextra-headers/cmake
> -DQt53DExtras_DIR=/root/QGIS/external/qt3dextra-headers/cmake/Qt53DExtras
> https://github.com/qgis/QGIS/blob/master/.docker/docker-qgis-build.sh#L48-L51
> for reference
> https://qgis-developer.osgeo.narkive.com/xMSz0lbQ/building-master-with-3d-on-debian-testing-buster
> Ciao,
> Denis
> Le lun. 4 oct. 2021 à 14:00, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> Hi,
>> I have been having problems compiling QGIS with 3D support on Kubuntu
>> 20.04. This is the CCMAKE configuration error:
>> CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
>> (find_package):
>>   Could not find a package configuration file provided by "Qt53DExtras"
>> with
>>   any of the following names:
>>     Qt53DExtrasConfig.cmake
>>     qt53dextras-config.cmake
>>   Add the installation prefix of "Qt53DExtras" to CMAKE_PREFIX_PATH or
>> set
>>   "Qt53DExtras_DIR" to a directory containing one of the above files.  If
>>   "Qt53DExtras" provides a separate development package or SDK, be sure
>> it
>>   has been installed.
>> Call Stack (most recent call first):
>>   CMakeLists.txt:455 (find_package)
>> I have libQt53DExtras installed, but there are no configuration files
>> like for other QT5 libraries. I tried to follow the suggestion and add the
>> installation prefix to CMAKE_PREFIX_PATH as suggested, but either it does
>> not work, or I am doing it wrong:
>> ccmake -G Ninja .. -DMAKE_PREFIX_PATH=/usr/lib/x86_64-linux-gnu/
>> Anyone is facing similar problems? any hint?
>> Thanks,
>> Alexandre Neto
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211004/4b31a967/attachment.html>
More information about the QGIS-Developer mailing list
