[QGIS-Developer] Boundless (docs) & Central provisioning of QGIS plugins...
Bourdon, Jean-François (DIF)
Jean-Francois.Bourdon at mffp.gouv.qc.ca
Mon Oct 4 10:19:18 PDT 2021
[Intranet logo]
It works like a charm! It also works when calling qgis_process so it means there is a way to use plugins outside the default profile (see https://github.com/qgis/QGIS/issues/44783). You made my day!
It seems that if there is any duplicated plugin (same name) in the default profile location and in the directory specified by QGIS_PLUGINPATH, only the latter will be loaded. It don't think it's bad, but I think this behaviour should be noted.
Jean-François Bourdon, ing.f.
Analyste en télédétection
Direction des inventaires forestiers
Ministère des Forêts, de la Faune et des Parcs
5700, 4e Avenue Ouest, local A-108
Québec (Québec) G1H 6R1
Téléphone : 418 627-8669, poste 704304
jean-francois.bourdon at mffp.gouv.qc.ca
mffp.gouv.qc.ca<http://www.mffp.gouv.qc.ca/accueil.jsp>
De : QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> De la part de Alexandre Neto
Envoyé : 4 octobre 2021 10:48
À : Andrea Aime <andrea.aime at geo-solutions.it>; Richard Duivenvoorde <rdmailings at duif.net>; Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
Cc : qgis-dev <Qgis-developer at lists.osgeo.org>
Objet : Re: [QGIS-Developer] Boundless (docs) & Central provisioning of QGIS plugins...
Regarding this subject,
I have found this on PyQGIS Cookbook:
Note
By setting QGIS_PLUGINPATH to an existing directory path, you can add this path to the list of paths that are searched for plugins.
So, I am guessing that one could set a folder with plugins in a network location and then setup this environment variable in each machine to have all the plugins available on all machines.
Just guessing, I didn't have the time to test it out.
Alexandre Neto
On Wed, Sep 15, 2021 at 6:55 PM Alexandre Neto <senhor.neto at gmail.com<mailto:senhor.neto at gmail.com>> wrote:
Hi Richard,
Several core commiters were working at BoundlessGeo back in those days, some are still there, in Planet Federal.
I was there too, and I was responsible for the documentation. Moving part of this documentation to QGIS Docs has been in my to do list for a while, but it never reached the top :-(
Sometime ago, I asked Alessandro Pasoti if those two settings were still valid, and he said that "AFAIK they were valid", but I abandoned the task before even trying it.
I still have the original rst files. In case anyone wants to jump on that task and try it out, I can share it.
Best regards,
Alexandre Neto
A quarta, 15/09/2021, 16:39, Andrea Aime <andrea.aime at geo-solutions.it<mailto:andrea.aime at geo-solutions.it>> escreveu:
On Wed, Sep 15, 2021 at 5:21 PM David Strip <qgis-dev at stripfamily.net<mailto:qgis-dev at stripfamily.net>> wrote:
according to Crunchbase<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.crunchbase.com%2Facquisition%2Fplanet-labs-acquires-boundlessgeo--320fb5e0&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748173971%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=QL0Ml9tmb2r46OKFHQWNGZrT7n7HCc2ovhitE4hN5EE%3D&reserved=0>, Boundless Spatial was acquired by Planet in 2018. Planet <https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.planet.com%2F&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748183967%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=X5GLaAEIViqpAuJyBhPcP9oXkRMqwwi0gEvrZTMr8kI%3D&reserved=0> still exists - I think it used to be called Planet Labs. It operates a constellation of small earth imaging satellites. I would guess that Boundless Spatial was absorbed into the mapping team<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.planet.com%2Fmarkets%2Fmapping%2F&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748193958%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=y96XlPrpnhma3PWrKmhoVPnDOvTq%2FPzqZfQBbowtQlU%3D&reserved=0>. But that's in information-free guess.
It actually became a new division, "Planet Federal": https://www.planet.com/pulse/planet-to-acquire-boundless/<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.planet.com%2Fpulse%2Fplanet-to-acquire-boundless%2F&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748193958%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=gZiULY8cy8rmNo45mXyerrhX%2FljrE7YfUlQvyx0%2Bucw%3D&reserved=0>
Cheers
Andrea
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-developer&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748203956%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=M38dKknFhwIYbADZTfnM8INOXrRuQvDzRIv7oOYS2j4%3D&reserved=0>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-developer&data=04%7C01%7C%7C554acea0f44a4108d37308d98745f23e%7C8705e97737814f4790e1c84c8b884da1%7C0%7C1%7C637689556748203956%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=M38dKknFhwIYbADZTfnM8INOXrRuQvDzRIv7oOYS2j4%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211004/2f06db89/attachment.html>
