[QGIS-Developer] QGIS not respecting WMTS cap tilematrixset
Bakker, Anton
Anton.Bakker at kadaster.nl
Wed Oct 13 13:24:43 PDT 2021
Hi all,
I submitted an issue (https://github.com/qgis/QGIS/issues/45460) on the issue tracker which is about QGIS not respecting the WMTS capabilities tilematrixset. @gioman On Github suggested to write to the mailing list. Considering it is a usability issue the developers mailing list seemed appropriate.
I do not think the current behaviour of QGIS is necessarily a bug, it might work as intended. But it does not match my expectation of how it ideally should work.
So the issue I ran into is the following:
I have a WMTS which only serves tiles for specific zoomlevels. So in the WMTS capabilities document we have a tilematrixset that starts from zoomlevel 05 (zoomlevels/tilematrices 00 - 04 are omitted), see the github issue for the full capabilities document to reproduce:
<TileMatrixSet>
<ows:Identifier>EPSG:28992</ows:Identifier>
<ows:SupportedCRS>urn:ogc:def:crs:EPSG::28992</ows:SupportedCRS>
<TileMatrix>
<ows:Identifier>05</ows:Identifier>
<ScaleDenominator>384000.0</ScaleDenominator>
<TopLeftCorner>-285401.92 903401.92</TopLeftCorner>
<TileWidth>256</TileWidth>
<TileHeight>256</TileHeight>
<MatrixWidth>32</MatrixWidth>
<MatrixHeight>32</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>06</ows:Identifier>
When adding this WMTS to the map in QGIS, QGIS zooms to the bounding box advertised in the capabilities (which corresponds to the extent of the Netherlands, and z0 in the Dutch national tiling scheme) and starts immediately loading tiles from the first available zoom level.
While I would expect QGIS to respect the service capabilities by default and only show tiles starting from the scale of the first available zoomlevel (which in this case is z05 which corresponds to a scale of 1:384000).
https://imgur.com/a/d31pEgU
My expectation is somewhat biased, since as a servicerpovider I would like to be in control of how our services are rendered in QGIS. The current situation does not allow for this, therefore I would like to propose the following :
QGIS by default respects the visibility of the WMTS layer as defined by the available tilematrixsets in the cap doc (I suppose this should be the case for all tiled resources, that make use of tilematrixsets). There are options on these layers to override this behaviour for both
- Lowerbound zoomlevels, configure from what zoomlevel tiles will be "underzoomed"
- Upperbound zoomlevels, configure till what zoomlevel tilles will be "overzoomed"
So I am curious what the community thinks, looking forward to the discussion.
Met vriendelijke groet,
Anton Bakker
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211013/ae99767a/attachment.html>
