[QGIS-Developer] RES: RES: Qgis 3.20.3 grass not working
jorgealmerio at yahoo.com.br
Thu Oct 14 12:24:50 PDT 2021
Hi Andrea,
You are totally right!
As I have Qgis 3.18.3 and 3.20.3 installed, and they have different
"Setups", I think I made some confusion.
Now When I chosed to reinstall 'grass' for the right qgis version,
everything has solved!
Thank you and sorry for this noise!
Jorge Almerio
-----Mensagem original-----
De: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Em nome
de Andrea Giudiceandrea
Enviada em: quinta-feira, 14 de outubro de 2021 12:45
Para: qgis-developer at lists.osgeo.org
Assunto: Re: [QGIS-Developer] RES: Qgis 3.20.3 grass not working
Hi Jorge,
I've used right now the OSGeo4W Network Installer with the "Advanced
Install" option selecting to install the packages "qgis" version
3.20.3-1 and "grass" version 7.8.6-1 in a clean "C:\OSGeo4W\" folder.
(The "qgis-grass-plugin" needs to be installed only if the "GRASS 7"
core plugin is needed.)
After the installation procedure, launching QGIS from the Start menu
shortcut link then QGIS doesn't show any issue about GRASS and the GRASS
algorithms are available in the Processing Toolbox.
There is only a "CRITICAL Problem installing SAGA: SAGA not found or not
installed" message, but it is normal since I've not installed SAGA.
Maybe you just need to use a new QGIS user profile or to install QGIS and
GRASS again in a clean folder.
Hope you could fix the issue.
Anyway, if you continue to experience such issue, probably it would be
better to open a new ticket in the OSGeo4W issue reporting system at
https://trac.osgeo.org/osgeo4w/
Best regards.
Andrea
Il 13/10/2021 17:52, jorgealmerio at yahoo.com.br ha scritto:
> Hi Andrea,
> I have used Advanced Install option.
> and I selected (see picture below):
> Desktop:
> grass: GRASS GIS
> Libs:
> qgis-grass-plugin: GRASS plugin for
> QGIS
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
