[QGIS-Developer] Disabling map context menu via PyQGIS
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Fri Sep 3 02:25:53 PDT 2021
Thank you guys so much for your great suggestions!
Since I am not already overriding QgsMapCanvas or using a custom MapTool
at all times, I went for Benoit's solution (which Benjamin hinted at)
and it works great.
A hundred internet points to you! :)
Cheers, Hannes
Am 03.09.21 um 09:58 schrieb Benoit Ducarouge:
> Hi,
> if you just want to hide the menu, you can clear it on the
> contextMenuAboutToShow event :
> def clearMenu(menu, event):
>     menu.clear()
> iface.mapCanvas().contextMenuAboutToShow.connect(clearMenu)
> Benoit.
> Le 03/09/2021 à 09:31, Benjamin Jakimow a écrit :
>> Hi Hannes,
>> in C++ you could override
>> void QgsMapCanvas::showContextMenu( QgsMapMouseEvent *event )
>> which creates and shows the context menu.
>> in Python showContextMenu is not available. There you could re-implement
>> void QgsMapCanvas::mousePressEvent( QMouseEvent *e ) to avoid any
>> calls of showContextMenu()
>> If you just like to modify the context menu, you might add a slot for
>> the
>> void contextMenuAboutToShow( QMenu *menu, QgsMapMouseEvent *event )
>> signal that manipulates the menu.
>> Greetings,
>> Benjamin
>> So you might either override it or
>> to disable the context menu you can override
More information about the QGIS-Developer mailing list
