[QGIS-Developer] SVG toolbar icons suddenly appearing in black
Raymond Nijssen
r.nijssen at terglobo.nl
Fri Sep 24 00:06:15 PDT 2021
Thank you all! Plenty workarounds for now. And I can also just wait for
them to upgrade to a new 3.16.x or higher.
Raymond
On 24-09-2021 08:31, Matthias Kuhn wrote:
> Hi Raymond,
> There has been an issue in Qt, where it was very picky with the
> <style> tag in the svg [1]
> This is solved in newer Qt versions (and newer QGIS for Windows builds)
> but is still present in the early QGIS 3.16 builds based on older Qt
> versions.
> The quick hack is to replace the <style> tag with <style
> type="text/css"> in the svg.
> Or upgrade to the latest QGIS version.
> Cheers
> Matthias
> https://bugreports.qt.io/browse/QTBUG-58326?focusedCommentId=344465&page=com.atlassian.jira.plugin.system.issuetabpanels%3Acomment-tabpanel#comment-344465
> <https://bugreports.qt.io/browse/QTBUG-58326?focusedCommentId=344465&page=com.atlassian.jira.plugin.system.issuetabpanels%3Acomment-tabpanel#comment-344465>
> On Fri, Sep 24, 2021 at 4:26 AM Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> On Thu, 23 Sept 2021 at 19:26, Raymond Nijssen
> <r.nijssen at terglobo.nl <mailto:r.nijssen at terglobo.nl>> wrote:
> > Hi devs!
> > The dark blue icons on my plugin toolbar buttons are black for
> some of
> > my customers (on Windows). One of them mentioned that they turned
> black
> > after a QGIS update. On my Linux system they are still blue. I
> guess it
> > has to do with Qt.
> Hi Raymond,
> I've seen this in the past. Seems that Qt on windows is more sensitive
> to SVG structure vs other platforms! In the past I've had luck by
> optimising the svg with https://jakearchibald.github.io/svgomg/
> <https://jakearchibald.github.io/svgomg/> ,
> which seems to make Qt happier... (Turn off "Round/rewrite numbers"
> option though, cos that makes Qt LESS happy!)
> Nyall
> > Here's the content of the svg file:
> > <svg xmlns="http://www.w3.org/2000/svg
> <http://www.w3.org/2000/svg>" viewBox="0 0 32 32">
> > <defs>
> > <style>
> > .a {
> > fill: #1b3d6e;
> > </style>
> > </defs>
> > <path class="a"
> d="M15.52,6.54a7.29,7.29,0,0,0-1.77,7.38l-9.9,9.9-.34,4.33,5.94-.6v-2.8h2.8V22h2.8l3.37-3.36a7.26,7.26,0,1,0-2.9-12Zm5.37,2.1a2,2,0,1,1,0,2.81A2,2,0,0,1,20.89,8.64Z"/>
> > </svg>
> > And here's how I make the buttons:
> > icon_fn = os.path.join(self.plugin_dir, 'img',
> 'icon_configuration.svg')
> > icon = QIcon(icon_fn)
> > action = QAction(icon, 'Configure', self.iface.mainWindow())
> > self.toolbar.addAction(action)
> > Hope anyone can clarify. The svg files were made by a designer, I
> guess
> > in some Adobe application. Hope I don't need adjusting them.
> > Kind regards,
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
