[QGIS-Developer] Plugin dependency with binaries: 'best' way to guide user to install?
Pedro Camargo
c at margo.co
Fri Apr 1 05:07:02 PDT 2022
Take a look at how it is done in the AequilibraE plugin.
I basically ship the plugin without the binaries and create a menu item where the user can choose to download the binaries.
Once downloaded, restarting the plugin allows it to identify the binaries and deactivate that menu item.
Cheers,
Pedro ---- On Fri, 01 Apr 2022 05:00:02 +1000 qgis-developer-request at lists.osgeo.org wrote ----Send QGIS-Developer mailing list submissions to
qgis-developer at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-developer
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-developer-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of QGIS-Developer digest..."
Today's Topics:
1. Plugin dependency with binaries: 'best' way to guide user to
install? (Aron Gergely)
2. Unexpected results from GPKG table query using executeSql()
(Raymond Nijssen)
3. Re: Unexpected results from GPKG table query using
executeSql() (Alessandro Pasotti)
4. Re: Unexpected results from GPKG table query using
executeSql() (Raymond Nijssen)
Message: 1
Date: Thu, 31 Mar 2022 14:09:21 +0200
To: qgis-dev <qgis-developer at lists.osgeo.org>
Subject: [QGIS-Developer] Plugin dependency with binaries: 'best' way
Message-ID: <5e3173ec-7b7e-64da-47d1-79d39edc1c10 at rasterra.nl>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi All,
What would be a good practice to handle 3rd party libs which can't be
shipped together with a plugin?
I am looking for the most user-friendly way and have an idea.
But thought I would bounce it off the collective wisdom here and see if
there are other/better ways.
If we find a 'best' method I could PR an update to the QGIS docs or
PyQGIS cookbook, etc to preserve that knowledge.
Bit of context:
I have a plugin that uses a 3rd party python library which has binaries.
I would like to submit this plugin to the official plugin repository.
According to https://plugins.qgis.org/publish/ it's not allowed to ship
binaries it with the plugin.
In such case the above webpage recommends telling the end user to run
"pip.main(...)" from the python console to install missing libraries.
I thought that's not user friendly and it's a pip hack (pip.main() is
meant to be internal).
Also, I want to handle the missing python module in my plugin
gracefully: check on plugin load if missing, if so, guide user to
resolve, preferably without having them write or copy any commands.
The idea:
Using python's subprocess module from within the plugin to call the pip
CLI, which would install the package the usual pip way. Here's why:
- pip project recommends this way as best practice, warns against the
pip.main()
- user would not need to write or copy-paste commands
- could make this user friendly: wire it in the plugin code to a push
button and build it into a dialog e.g.;? if lib is missing on plugin load,
? show a QMessageBox and let user open a dialog to resolve. In that
dialog would be the push button to trigger the pip install via subprocess.
How would this play out multi-platform via subprocess, I have no idea of
yet - thought if the idea survived this thread, I'd go find out ;)
Do you think this subprocess + pip is a good idea?
Would it be allowed for plugins in the official repository to behave as
such?
Anyone has other user-friendly ways of doing this?
Best regards,
Aron
Message: 2
Date: Thu, 31 Mar 2022 18:09:25 +0200
To: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: [QGIS-Developer] Unexpected results from GPKG table query
using executeSql()
Message-ID: <bba11f52-a64a-6502-fbce-dbc986ba9391 at terglobo.nl>
Hi devs,
I'm working on a plugin that connects to a custom table (without
geometry) in a GPKG. When I'm sending queries to it, I keep on getting
unexpected results. Somehow the id field is missing, sometimes it
appears twice (!). And this seems to be different between QGIS 3.10 and
3.25. (I think it changed since 3.22).
Here is a piece of my code:
fn = '/path/to/test.gpkg'
md = QgsProviderRegistry.instance().providerMetadata('ogr')
conn = md.createConnection(fn, {})
q = 'select * from test_table;'
qr = conn.executeSql(q)
print(qr) # No id field in result
Before diving into the QGIS code I'd like to check if this is the way to
go. Or should i use another way to query that GPKG (SQLite) db?
Kind regards,
Raymond
Message: 3
Date: Thu, 31 Mar 2022 18:15:00 +0200
To: Raymond Nijssen <r.nijssen at terglobo.nl>
Cc: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Unexpected results from GPKG table query
using executeSql()
Message-ID:
<CAL5Q670rrD--ZvEVDTtCWEqU1vZgUe7Nh+e58MLMDMQNPF9h1w at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hi Raymond,
your code looks good.
Can you provide a test file?
There are some test in core here:
https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py
On Thu, Mar 31, 2022 at 6:09 PM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi devs,
> Kind regards,
> Raymond
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220331/ad1ec7b7/attachment-0001.html>
Message: 4
Date: Thu, 31 Mar 2022 18:52:48 +0200
To: Alessandro Pasotti <apasotti at gmail.com>
using executeSql()
Message-ID: <87330c53-a8a5-6e07-dd6e-006fcdd7710f at terglobo.nl>
Hi Alessandro,
Thanks for your reply. Will share data and a test script with you privately.
Raymond
On 31-03-2022 18:15, Alessandro Pasotti wrote:
> Hi Raymond,
> <https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py>
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Hi devs,
> way to
> Kind regards,
> Raymond
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Alessandro Pasotti
> QCooperative: www.qcooperative.net <https://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
Subject: Digest Footer
End of QGIS-Developer Digest, Vol 197, Issue 39
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220401/7809c541/attachment.html>
