[QGIS-Developer] Plugin dependency with binaries: 'best' way to guide user to install?
Pedro Camargo
c at margo.co
Tue Apr 5 15:10:07 PDT 2022
Hey Aron,
I did explore that route, but I found out that it would fail when the user did not have administrator rights (or even if QGIS had not been ran as administrator on Windows). Did you find it to be different?
Cheers,
Pedro
---- On Wed, 06 Apr 2022 03:28:09 +1000 Aron Gergely <aron.gergely at rasterra.nl> wrote ----
Thank you, I checked out your plugin - yes that seems also a good
way.
I already had the logic to detect, throw message, guide to dialog,
etc... implemented similar to yours.
But I wanted to let pip manage the actual package, so I went with
the subprocess+pip route. Here is a minimum working example:
import subprocess
import sys
try:
subprocess.check_call((sys.executable, '-m', 'pip', 'install', 'h3<=3.99'))
except subprocess.CalledProcessError as e:
raise e # handle any errors here instead
I connected it to a button in a dialog. And catch stdout, stderr
and the exit code of the subprocess so I can show the user what is
happening.
Have not yet tried on other platforms than Linux. But
sys.executable is there to solve the ambiguity of python
executable path.
Best regards,
Aron
On 01-04-2022 14:07, Pedro Camargo via
QGIS-Developer wrote:
Take
a look at how it is done in the AequilibraE plugin.
I basically ship the plugin without the binaries and create a
menu item where the user can choose to download the binaries.
Once downloaded, restarting the plugin allows it to identify the
binaries and deactivate that menu item.
Cheers,
Pedro
---- On Fri, 01 Apr 2022 05:00:02 +1000 mailto:qgis-developer-request at lists.osgeo.org wrote ----
Send QGIS-Developer mailing list submissions to
mailto:qgis-developer at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-developer
or, via email, send a message with subject or body 'help'
to
You can reach the person managing the list at
mailto:qgis-developer-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more
specific
than "Re: Contents of QGIS-Developer digest..."
Today's Topics:
1. Plugin dependency with binaries: 'best' way to guide
user to
install? (Aron Gergely)
2. Unexpected results from GPKG table query using
executeSql()
(Raymond Nijssen)
3. Re: Unexpected results from GPKG table query using
executeSql() (Alessandro Pasotti)
4. Re: Unexpected results from GPKG table query using
executeSql() (Raymond Nijssen)
Message: 1
Date: Thu, 31 Mar 2022 14:09:21 +0200
From: Aron Gergely <mailto:aron.gergely at rasterra.nl>
To: qgis-dev <mailto:qgis-developer at lists.osgeo.org>
Subject: [QGIS-Developer] Plugin dependency with binaries:
'best' way
Message-ID: <5e3173ec>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi All,
What would be a good practice to handle 3rd party libs
which can't be
shipped together with a plugin?
I am looking for the most user-friendly way and have an
idea.
But thought I would bounce it off the collective wisdom
here and see if
there are other/better ways.
If we find a 'best' method I could PR an update to the
QGIS docs or
PyQGIS cookbook, etc to preserve that knowledge.
Bit of context:
I have a plugin that uses a 3rd party python library which
has binaries.
I would like to submit this plugin to the official plugin
repository.
According to https://plugins.qgis.org/publish/ it's not allowed to ship
binaries it with the plugin.
In such case the above webpage recommends telling the end
user to run
"pip.main(...)" from the python console to install missing
libraries.
I thought that's not user friendly and it's a pip hack
(pip.main() is
meant to be internal).
Also, I want to handle the missing python module in my
plugin
gracefully: check on plugin load if missing, if so, guide
user to
resolve, preferably without having them write or copy any
commands.
The idea:
Using python's subprocess module from within the plugin to
call the pip
CLI, which would install the package the usual pip way.
Here's why:
- pip project recommends this way as best practice, warns
against the
pip.main()
- user would not need to write or copy-paste commands
- could make this user friendly: wire it in the plugin
code to a push
button and build it into a dialog e.g.;? if lib is missing
on plugin load,
? show a QMessageBox and let user open a dialog to
resolve. In that
dialog would be the push button to trigger the pip install
via subprocess.
How would this play out multi-platform via subprocess, I
have no idea of
yet - thought if the idea survived this thread, I'd go
find out ;)
Do you think this subprocess + pip is a good idea?
Would it be allowed for plugins in the official repository
to behave as
such?
Anyone has other user-friendly ways of doing this?
Best regards,
Aron
Message: 2
Date: Thu, 31 Mar 2022 18:09:25 +0200
From: Raymond Nijssen <mailto:r.nijssen at terglobo.nl>
To: qgis-developer <mailto:qgis-developer at lists.osgeo.org>
Subject: [QGIS-Developer] Unexpected results from GPKG
table query
using executeSql()
Message-ID: <bba11f52>
Hi devs,
I'm working on a plugin that connects to a custom table
(without
geometry) in a GPKG. When I'm sending queries to it, I
keep on getting
unexpected results. Somehow the id field is missing,
sometimes it
appears twice (!). And this seems to be different between
QGIS 3.10 and
3.25. (I think it changed since 3.22).
Here is a piece of my code:
fn = '/path/to/test.gpkg'
md =
QgsProviderRegistry.instance().providerMetadata('ogr')
conn = md.createConnection(fn, {})
q = 'select * from test_table;'
qr = conn.executeSql(q)
print(qr) # No id field in result
Before diving into the QGIS code I'd like to check if this
is the way to
go. Or should i use another way to query that GPKG
(SQLite) db?
Kind regards,
Raymond
Message: 3
Date: Thu, 31 Mar 2022 18:15:00 +0200
From: Alessandro Pasotti <mailto:apasotti at gmail.com>
To: Raymond Nijssen <mailto:r.nijssen at terglobo.nl>
Cc: qgis-developer <mailto:qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Unexpected results from GPKG
table query
using executeSql()
Message-ID:
<CAL5Q670rrD--ZvEVDTtCWEqU1vZgUe7Nh>
Content-Type: text/plain; charset="utf-8"
Hi Raymond,
your code looks good.
Can you provide a test file?
There are some test in core here:
https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py
On Thu, Mar 31, 2022 at 6:09 PM Raymond Nijssen via
QGIS-Developer <
wrote:
> Hi devs,
table (without
I keep on getting
sometimes it
between QGIS 3.10 and
> md =
this is the way to
(SQLite) db?
> Kind regards,
> Raymond
> mailto:QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: http://www.qcooperative.net
ItOpen: http://www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220331/ad1ec7b7/attachment-0001.html>
Message: 4
Date: Thu, 31 Mar 2022 18:52:48 +0200
To: Alessandro Pasotti <mailto:apasotti at gmail.com>
table query
using executeSql()
Message-ID: <87330c53>
Hi Alessandro,
Thanks for your reply. Will share data and a test script
with you privately.
Raymond
On 31-03-2022 18:15, Alessandro Pasotti wrote:
> Hi Raymond,
> <https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py>
QGIS-Developer
> <mailto:qgis-developer at lists.osgeo.org <mailto:mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Hi devs,
table (without
I keep on getting
sometimes it
> md =
this is the
> way to
(SQLite) db?
> Kind regards,
> Raymond
> mailto:QGIS-Developer at lists.osgeo.org <mailto:mailto:QGIS-Developer at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Alessandro Pasotti
> QCooperative: http://www.qcooperative.net <https://www.qcooperative.net>
> ItOpen: http://www.itopen.it <http://www.itopen.it>
Subject: Digest Footer
End of QGIS-Developer Digest, Vol 197, Issue 39
Kind Regards,
Aron Gergely
+31 (0) 6 38 70 97 66
Rasterra | http://www.rasterra.nl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220406/f59c1402/attachment-0001.html>
