[QGIS-Developer] Plugin dependency with binaries: 'best' way to guide user to install?
Benjamin Jakimow benjamin.jakimow at geo.hu-berlin.de
Wed Apr 6 06:17:00 PDT 2022
Hi Aron,
with the EnMAP-Box plugin we are confronted with missing PIP packages
quite often. Therefore we implemented a "PIP Package Installer"
(screenshot below, source code here:
https://bitbucket.org/hu-geomatics/enmap-box/src/develop/enmapbox/dependencycheck.py)
In case of missing admin rights you can use the PIP "--user" argument to
install packages to the user's home folder
D:\OSGeo4W\bin\python3.EXE -m pip install --user lightgbm
The absolute python executable path can be retrieved with
"shutil.which('python') "
Greetings,
Benjamin
On 2022-04-06 14:01, Aron Gergely via QGIS-Developer wrote:
> @Pedro:
> Tried it today on Windows w OSGeo QGIS and failed right away. But in a
> different way:
> If I launch OSGeo QGIS and ask for the python executable's path
> (sys.executabe), I get 'C:/OSGeo4W/bin/qgis-bin.exe'. which looks like
> entry point is for QGIS.  So subprocess calls that and a new QGIS
> window opens.
> Not feeling like tackling this and probably other cases.
> So back to download+including those bins I reckon.
> @Johannes:
> Thank you. Yes realizing that now..
> Cheers,
> Aron
> On 06-04-2022 12:12, Johannes Kröger (WhereGroup) wrote:
> Trying to find a smart way to install Python dependencies for the users
> that will not potentially not work or even break stuff is a very hard
> thing(tm). Check out these two QEPs for a lot of discussion and
> possible approaches:
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/202
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/179
> Cheers, Hannes
> Am 06.04.22 um 00:10 schrieb Pedro Camargo via QGIS-Developer:
> Hey Aron,
> I did explore that route, but I found out that it would fail when the
> user did not have administrator rights (or even if QGIS had not been
> ran as administrator on Windows).  Did you find it to be different?
> Cheers,
> Pedro
> ---- On Wed, 06 Apr 2022 03:28:09 +1000 Aron Gergely
> <aron.gergely at rasterra.nl> wrote ----
> Thank you, I checked out your plugin - yes that seems also a good way.
> I already had the logic to detect, throw message, guide to dialog,
> etc... implemented similar to yours.
> But I wanted to let pip manage the actual package, so I went with the
> subprocess+pip route. Here is a minimum working example:
> import subprocess
> import sys
> try:
> subprocess.check_call((sys.executable, '-m', 'pip', 'install',
> 'h3<=3.99'))
> except subprocess.CalledProcessError as e:
> raise e  # handle any errors here instead
> I connected it to a button in a dialog. And catch stdout, stderr and
> the exit code of the subprocess so I can show the user what is
> happening.
> Have not yet tried on other platforms than Linux. But sys.executable is
> there to solve the ambiguity of python executable path.
> Best regards,
> Aron
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
johannes.kroeger at wheregroup.com
www.wheregroup.com [1]
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Kind Regards,
Aron Gergely
+31 (0) 6 38 70 97 66
Rasterra | www.rasterra.nl [2]
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Benjamin Jakimow, Doctoral Researcher
Earth Observation Lab | Geography Department | Humboldt-Universität zu
Berlin
e-mail: benjamin.jakimow at geo.hu-berlin.de
phone:  +49 (0) 30 2093 6894
mobile: +49 (0) 157 5656 8477
fax:    +49 (0) 30 2093 6848
mail:   Unter den Linden 6 | 10099 Berlin | Germany
room: 2'222
Links:
[1] http://www.wheregroup.com
[2] http://www.rasterra.nl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220406/0572bf39/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220406/0572bf39/attachment-0001.png>
More information about the QGIS-Developer mailing list
