[QGIS-Developer] Questions of a newbie starting with QGIS Server
Richard Duivenvoorde rdmailings at duif.net
Thu Apr 21 03:04:15 PDT 2022
On 4/21/22 11:57, DelazJ wrote:
>     The GDAL_DATA path you will need when you use for example the ECW or other drivers
>     QGIS_AUTH_DB_DIR_PATH is maybe only needed when you have a project which uses authentication profiles? Others?
> So it could make sense to have them added to the default httpd_qgis.conf file...?
Probably yes, others?
Regards,
Richard
More information about the QGIS-Developer mailing list
