[QGIS-Developer] Inserting provider filter just before PostGIS layer is loaded?
Jacky Volpes
jacky.volpes at oslandia.com
Mon Aug 22 03:11:21 PDT 2022
I don't know any way to do this, except for using a workaround.
But it will depend on your use-case.
Maybe using query layers, such as
QgsVectorLayer("table='(select * from <schema>.<table> <your
conditions>)' service='<service>' key='<unique id column>'", "<table
name>", "postgres")
can help ?
Regards,
Jacky
Le 09/08/2022 à 11:15, Johannes Kröger (WhereGroup) via QGIS-Developer a
écrit :
> Howdy!
> I'd like to force a provider filter when a user adds a PostGIS layer
> and have it applied *before* any data is loaded. Setting it after the
> layer (and some of its big data) is loaded initially is not an option.
> Is there a way to sneak in between "user clicked something in the GUI
> to load a table/query and QGIS will construct a QgsVectorLayer now"
> and "QGIS now talks to the PostGIS database to get the data for the
> new layer", maybe with a signal?
> Something like a "layerAboutToBeLoaded" (like the opposite
> layerWillBeRemoved on
> https://qgis.org/pyqgis/master/core/QgsProject.html) basically. :o)
> Cheers, Hannes
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jacky Volpes
Ingénieur SIG - Oslandia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220822/8f435c7a/attachment.htm>
