[QGIS-Developer] Unable to build master on Ubuntu 22.04
Delaz J
delazj at gmail.com
Wed Aug 24 10:23:01 PDT 2022
Richard, I cleared the cache and rebuilt and everything is fine now.
Thanks a lot.
Jorge, thanks also for the info, and yes `gcc --version` returns gcc
(Ubuntu 11.2.0-19ubuntu1) 11.2.0
Greetings,
Harrissou
Le 24/08/2022 à 13:19, Jorge Gustavo Rocha via QGIS-Developer a écrit :
> Hi Harrissou,
> Recently our PDAL friends introduced in CMakeLists.txt:
> set(CMAKE_CXX_STANDARD 17)
> set(CMAKE_CXX_STANDARD_REQUIRED ON)
> For those compiling PDAL + GDAL + QGIS, maybe we need to use gcc-11.
> Is this you case?
> Building QGIS and all required software works on my 22.04 (with gcc-11).
> Best regards,
> Jorge
> On 24/08/22 11:33, Delaz J via QGIS-Developer wrote:
>> Hi devs,
>> I had a working build of QGIS master on ubuntu 22.04. Everything
>> worked nicely but because it was minimum 2/3 weeks old, I pulled
>> changes from upstream and tried to rebuild. Fail! I then deleted my
>> build folder and redo a ccmake -G Ninja .., configured (no big
>> changes other than Debug cmake_build_type, with_3D on and no GRASS)
>> and launched the build. Still nothing. It just fails and I see no
>> information why. Any idea how to fix or how I can output error
>> reasons would be really appreciated.
>> Below all that I get.
>> Thanks and kind regards,
>> Harrissou
>> > ninja -j4 && ./output/bin/qgis
>> [9/1820] Building CXX object
>> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o
>> FAILED: src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o
>> ccache /usr/bin/c++ -DQT_3DCORE_LIB -DQT_3DEXTRAS_LIB
>> -DQT_3DINPUT_LIB -DQT_3DLOGIC_LIB -DQT_3DRENDER_LIB
>> -DQT_CONCURRENT_LIB -DQT_CORE_LIB -DQT_DBUS_LIB
>> -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050800
>> -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_CAST_TO_ASCII -DQT_NO_FOREACH
>> -DQT_POSITIONING_LIB -DQT_PRINTSUPPORT_LIB -DQT_QMLMODELS_LIB
>> -DQT_QML_LIB -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_SERIALPORT_LIB
>> -DQT_SQL_LIB -DQT_SVG_LIB -DQT_UITOOLS_LIB -DQT_USE_QSTRINGBUILDER
>> -DQT_WEBKITWIDGETS_LIB -DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB
>> -DSIP_VERSION=0x060501
>> -DTEST_DATA_DIR=\"/media/delazj/github/QGIS/tests/testdata\"
>> -DWITH_BINDINGS -DWITH_QTWEBKIT -Dqgis_app_EXPORTS
>> -I/media/delazj/github/QGIS/build-ninja/src/app/qgis_app_autogen/include
>> -I/media/delazj/github/QGIS/external/nmea
>> -I/media/delazj/github/QGIS/src/app
>> -I/media/delazj/github/QGIS/src/app/decorations
>> -I/media/delazj/github/QGIS/src/app/devtools/networklogger
>> -I/media/delazj/github/QGIS/src/app/labeling
>> -I/media/delazj/github/QGIS/src/app/layout
>> -I/media/delazj/github/QGIS/src/app/pluginmanager
>> -I/media/delazj/github/QGIS/src/app/gps
>> -I/media/delazj/github/QGIS/src/app/dwg
>> -I/media/delazj/github/QGIS/src/app/maptools
>> -I/media/delazj/github/QGIS/src/app/mesh
>> -I/media/delazj/github/QGIS/src/app/locator
>> -I/media/delazj/github/QGIS/src/app/pointcloud
>> -I/media/delazj/github/QGIS/src/app/vectortile
>> -I/media/delazj/github/QGIS/src/plugins
>> -I/media/delazj/github/QGIS/src/python
>> -I/media/delazj/github/QGIS/src/native
>> -I/media/delazj/github/QGIS/src/app/3d
>> -I/media/delazj/github/QGIS/src/core
>> -I/media/delazj/github/QGIS/build-ninja/src/core
>> -I/media/delazj/github/QGIS/src/core/3d
>> -I/media/delazj/github/QGIS/src/core/annotations
>> -I/media/delazj/github/QGIS/src/core/auth
>> -I/media/delazj/github/QGIS/src/core/browser
>> -I/media/delazj/github/QGIS/src/core/callouts
>> -I/media/delazj/github/QGIS/src/core/classification
>> -I/media/delazj/github/QGIS/src/core/diagram
>> -I/media/delazj/github/QGIS/src/core/dxf
>> -I/media/delazj/github/QGIS/src/core/editform
>> -I/media/delazj/github/QGIS/src/core/effects
>> -I/media/delazj/github/QGIS/src/core/elevation
>> -I/media/delazj/github/QGIS/src/core/expression
>> -I/media/delazj/github/QGIS/src/core/externalstorage
>> -I/media/delazj/github/QGIS/src/core/fieldformatter
>> -I/media/delazj/github/QGIS/src/core/geometry
>> -I/media/delazj/github/QGIS/src/core/geocms
>> -I/media/delazj/github/QGIS/src/core/geocms/geonode
>> -I/media/delazj/github/QGIS/src/core/geocoding
>> -I/media/delazj/github/QGIS/src/core/gps
>> -I/media/delazj/github/QGIS/src/core/labeling
>> -I/media/delazj/github/QGIS/src/core/layertree
>> -I/media/delazj/github/QGIS/src/core/layout
>> -I/media/delazj/github/QGIS/src/core/locator
>> -I/media/delazj/github/QGIS/src/core/maprenderer
>> -I/media/delazj/github/QGIS/src/core/mesh
>> -I/media/delazj/github/QGIS/src/core/metadata
>> -I/media/delazj/github/QGIS/src/core/network
>> -I/media/delazj/github/QGIS/src/core/numericformats
>> -I/media/delazj/github/QGIS/src/core/pal
>> -I/media/delazj/github/QGIS/src/core/plot
>> -I/media/delazj/github/QGIS/src/core/pointcloud
>> -I/media/delazj/github/QGIS/src/core/pointcloud/expression
>> -I/media/delazj/github/QGIS/src/core/processing
>> -I/media/delazj/github/QGIS/src/core/processing/models
>> -I/media/delazj/github/QGIS/src/core/proj
>> -I/media/delazj/github/QGIS/src/core/project
>> -I/media/delazj/github/QGIS/src/core/providers
>> -I/media/delazj/github/QGIS/src/core/providers/arcgis
>> -I/media/delazj/github/QGIS/src/core/providers/memory
>> -I/media/delazj/github/QGIS/src/core/providers/gdal
>> -I/media/delazj/github/QGIS/src/core/providers/ogr
>> -I/media/delazj/github/QGIS/src/core/providers/meshmemory
>> -I/media/delazj/github/QGIS/src/core/raster
>> -I/media/delazj/github/QGIS/src/core/renderer
>> -I/media/delazj/github/QGIS/src/core/scalebar
>> -I/media/delazj/github/QGIS/src/core/settings
>> -I/media/delazj/github/QGIS/src/core/symbology
>> -I/media/delazj/github/QGIS/src/core/textrenderer
>> -I/media/delazj/github/QGIS/src/core/validity
>> -I/media/delazj/github/QGIS/src/core/vector
>> -I/media/delazj/github/QGIS/src/core/vectortile
>> -I/media/delazj/github/QGIS/external/nlohmann
>> -I/media/delazj/github/QGIS/external/kdbush/include
>> -I/media/delazj/github/QGIS/external/rtree/include
>> -I/media/delazj/github/QGIS/external/meshOptimizer
>> -I/media/delazj/github/QGIS/src/core/providers/ept
>> -I/media/delazj/github/QGIS/src/core/providers/copc
>> -I/media/delazj/github/QGIS/src/gui
>> -I/media/delazj/github/QGIS/src/gui/annotations
>> -I/media/delazj/github/QGIS/src/gui/attributeformconfig
>> -I/media/delazj/github/QGIS/src/gui/symbology
>> -I/media/delazj/github/QGIS/src/gui/attributetable
>> -I/media/delazj/github/QGIS/src/gui/auth
>> -I/media/delazj/github/QGIS/src/gui/callouts
>> -I/media/delazj/github/QGIS/src/gui/codeeditors
>> -I/media/delazj/github/QGIS/src/gui/devtools
>> -I/media/delazj/github/QGIS/src/gui/editorwidgets
>> -I/media/delazj/github/QGIS/src/gui/editorwidgets/core
>> -I/media/delazj/github/QGIS/src/gui/effects
>> -I/media/delazj/github/QGIS/src/gui/elevation
>> -I/media/delazj/github/QGIS/src/gui/history
>> -I/media/delazj/github/QGIS/src/gui/labeling
>> -I/media/delazj/github/QGIS/src/gui/layertree
>> -I/media/delazj/github/QGIS/src/gui/layout
>> -I/media/delazj/github/QGIS/src/gui/locator
>> -I/media/delazj/github/QGIS/src/gui/maptools
>> -I/media/delazj/github/QGIS/src/gui/mesh
>> -I/media/delazj/github/QGIS/src/gui/numericformats
>> -I/media/delazj/github/QGIS/src/gui/ogr
>> -I/media/delazj/github/QGIS/src/gui/plot
>> -I/media/delazj/github/QGIS/src/gui/processing
>> -I/media/delazj/github/QGIS/src/gui/processing/models
>> -I/media/delazj/github/QGIS/src/gui/providers
>> -I/media/delazj/github/QGIS/src/gui/providers/gdal
>> -I/media/delazj/github/QGIS/src/gui/providers/ogr
>> -I/media/delazj/github/QGIS/src/gui/pointcloud
>> -I/media/delazj/github/QGIS/src/gui/raster
>> -I/media/delazj/github/QGIS/src/gui/settings
>> -I/media/delazj/github/QGIS/src/gui/tableeditor
>> -I/media/delazj/github/QGIS/src/gui/vector
>> -I/media/delazj/github/QGIS/src/gui/vectortile
>> -I/media/delazj/github/QGIS/build-ninja/src/gui
>> -I/media/delazj/github/QGIS/build-ninja/src/ui
>> -I/media/delazj/github/QGIS/src/gui/providers/ept
>> -I/media/delazj/github/QGIS/src/gui/providers/copc
>> -I/media/delazj/github/QGIS/build-ninja/src/native
>> -I/media/delazj/github/QGIS/src/analysis
>> -I/media/delazj/github/QGIS/src/analysis/georeferencing
>> -I/media/delazj/github/QGIS/src/analysis/interpolation
>> -I/media/delazj/github/QGIS/src/analysis/mesh
>> -I/media/delazj/github/QGIS/src/analysis/network
>> -I/media/delazj/github/QGIS/src/analysis/processing
>> -I/media/delazj/github/QGIS/src/analysis/raster
>> -I/media/delazj/github/QGIS/src/analysis/vector
>> -I/media/delazj/github/QGIS/src/analysis/vector/geometry_checker
>> -I/media/delazj/github/QGIS/build-ninja/src/analysis
>> -I/media/delazj/github/QGIS/external/libdxfrw
>> -I/media/delazj/github/QGIS/build-ninja/src/python
>> -I/media/delazj/github/QGIS/src/3d
>> -I/media/delazj/github/QGIS/src/3d/chunks
>> -I/media/delazj/github/QGIS/src/3d/lights
>> -I/media/delazj/github/QGIS/src/3d/materials
>> -I/media/delazj/github/QGIS/src/3d/mesh
>> -I/media/delazj/github/QGIS/src/3d/processing
>> -I/media/delazj/github/QGIS/src/3d/shaders
>> -I/media/delazj/github/QGIS/src/3d/symbols
>> -I/media/delazj/github/QGIS/src/3d/terrain
>> -I/media/delazj/github/QGIS/build-ninja/src/3d
>> -I/media/delazj/github/QGIS/external/delaunator-cpp -isystem
>> /usr/include/postgresql -isystem
>> /media/delazj/github/QGIS/external/qt-unix-signals -isystem
>> /usr/include/x86_64-linux-gnu/qt5 -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem
>> /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtUiTools -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtWebKitWidgets -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtWebKit -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem
>> /usr/include/gdal -isystem /usr/include/Qca-qt5/QtCrypto -isystem
>> /usr/include/qt5keychain -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtPositioning -isystem
>> /usr/include/qwt -isystem /usr/include/x86_64-linux-gnu/qt5/QtDBus
>> -isystem /usr/include/x86_64-linux-gnu/qt5/QtQuickWidgets -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtQuick -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtQmlModels -isystem
>> /usr/include/x86_64-linux-gnu/qt5/QtQml -isystem
>> /usr/include/x86_64-linux-gnu/qt5/Qt3DCore -isystem
>> /usr/include/x86_64-linux-gnu/qt5/Qt3DRender -isystem
>> /usr/include/x86_64-linux-gnu/qt5/Qt3DInput -isystem
>> /usr/include/x86_64-linux-gnu/qt5/Qt3DLogic -isystem
>> /usr/include/x86_64-linux-gnu/qt5/Qt3DExtras -Wall -Wextra
>> -Wno-long-long -Wformat-security -Wno-strict-aliasing
>> -Wnon-virtual-dtor -Wno-redundant-move -Wno-misleading-indentation
>> -Wno-deprecated-copy -g -fPIC -fvisibility=hidden -fPIC -MD -MT
>> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o -MF
>> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o.d -o
>> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o -c
>> /media/delazj/github/QGIS/src/app/qgisapp.cpp
>> c++: fatal error: Processus arrêté signal terminated program cc1plus
>> compilation terminated.
>> [12/1820] Building CXX object
>> src/app/CMakeFiles/qgis_app.dir/qgsattributetabledialog.cpp.o
>> ninja: build stopped: subcommand failed.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
