[QGIS-Developer] msi package error
Paul N
surveykshak at gmail.com
Sat Dec 3 22:22:26 PST 2022
Hi Jurgen,
First of all, I would like to thank you for your reply and it works fine.
While downloading packages by createmsi.pl, it's not downloading GRASS and
SAGA. Where I have to change the script or something else to get the GRASS
and SAGA.
Regard
Paul N
On Thu, 10 Nov 2022 at 21:49, Jürgen E. Fischer via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Paul,
> On Thu, 10. Nov 2022 at 21:25:53 +0530, Paul N via QGIS-Developer wrote:
> > After running createmsi.pl following folders created
> > C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp
> > C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\packages
> > C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\unpacked
> > then I have moved Installer-Files folder to tmp
> > C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\Installer-Files
> > Now after running createmsi.pl
> > It give output as
> > PS C:\OSGeo4W\QGIS_3_22\ms-windows\scripts> perl .\createmsi.pl
> This is supposed to run from cygwin and not powershell.
> > Where "FIND: Parameter format not correct" ?
> That's Windows' find, the scripts expects a "regular" (GNU) find, which
> will be
> available when run from cygwin.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221204/3c436d1a/attachment.htm>
