[QGIS-Developer] Fwd: Dear develop team GIS (plugin)
Richard Duivenvoorde rdmailings at duif.net
Wed Dec 7 07:26:35 PST 2022
I do not have an email address of NyakudayaE, but I asked the perion if it is OK like it is now:
https://github.com/IFEERnD/Q5Pfes/issues/1
(https://plugins.qgis.org/plugins/q5pfes/ has no public version yet)
Regards,
On 12/7/22 03:33, Dương Phạm Quang wrote:
> Dear Richard,
> Thanks for your guidance, I tried deleting the old plugin and pushing the version with the new name but it's been more than 3 weeks now but I still haven't received a response or approval.
> Can you please check in your account's upload plugin list "ifeernd".
> Or you can give me the email channels email address so I can contact them
> Thank you!*
> Vào Th 6, 28 thg 10, 2022 vào lúc 14:35 Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>> đã viết:
>     Hi,
>     I think you just have to remove the earlier version (or let me do the removal).
>     And then upload the new version with the new name, which will then start with 1.2 as first version.
>     Let me know if you want me to delete that version.
>     (note: it is better to communicate via the email channels, then others also can help)
>     Regards,
>     On 10/28/22 06:43, Dương Phạm Quang wrote:
>      > thank for you support, our first version have been successful upload to QGIS Plugin. But we have a new decision to change our plugin name. Can you help us in this case?
>      > Vào Th 4, 19 thg 10, 2022 vào lúc 14:24 Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net> <mailto:rdmailings at duif.net <mailto:rdmailings at duif.net>>> đã viết:
>      >     The author just sent me the github repo:
>      >     "Our link repo is: https://github.com/IFEERnD/v5Pfes <https://github.com/IFEERnD/v5Pfes> <https://github.com/IFEERnD/v5Pfes <https://github.com/IFEERnD/v5Pfes>>"
>      >     @Pham Quang Duong am I right that this plugin is only in Vietnamees language?
>      >     Can you maybe provide some information (in english, in the README.txt (which is now empty)) about what the plugin is supposed to do, or maybe a little guide about how to test?
>      >     Most people approving the plugins are English speaking/reading ( or at least without knowledge of Vietnamees writing :-) ) , so without any guidance cannot tell what the plugin is doing, unless they deep dive into the code.
>      >     Regards,
>      >     On 10/19/22 09:13, Werner Macho wrote:
>      >      > Hi Richard,
>      >      > I also searched for the user id "ifeernd" - and could not find it.
>      >      > Maybe it is not a plugin and something completely different is meant?
>      >      > regards
>      >      > werner
>      >      > On Wed, Oct 19, 2022 at 9:02 AM Richard Duivenvoorde via QGIS-Developer <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> <mailto:qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>> <mailto:qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> <mailto:qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>>> wrote:
>      >      >     Hi Devs,
>      >      >     This mail was (accidently wrong) sent to the list owner of the dev list.
>      >      >     Sender tells us a plugin was sent in 2 weeks ago.
>      >      >     If I search for V5Pfes I only see 'None', if I search for Forest I see None again.
>      >      >     Is there something wrong with the metadata of the plugin?
>      >      >     I think I normally see the name of the plugin, even when it is not approved?
>      >      >     @Pham Quang Duong can you maybe sent the link of you repo?
>      >      >     Regards,
>      >      >     Richard Duivenvoorde
>      >      >     -------- Forwarded Message --------
>      >      >     Subject:        Dear develop team GIS
>      >      >     Date:   Tue, 18 Oct 2022 16:47:19 +0700
>      >      >     From:   Dương Phạm Quang <phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn>> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn>>>>
>      >      >     To: qgis-developer-owner at lists.osgeo.org <mailto:qgis-developer-owner at lists.osgeo.org> <mailto:qgis-developer-owner at lists.osgeo.org <mailto:qgis-developer-owner at lists.osgeo.org>> <mailto:qgis-developer-owner at lists.osgeo.org <mailto:qgis-developer-owner at lists.osgeo.org> <mailto:qgis-developer-owner at lists.osgeo.org <mailto:qgis-developer-owner at lists.osgeo.org>>>
>      >      >     We are trying to release a tool to support the construction of V5Pfes Forest Environmental Services Payment Map on the QGIS platform called V5Pfes. The account we use has an id of "ifeernd".
>      >      >     However, it has been more than 2 weeks since pushing the first version, but we still have not received a response to edit or approved version.
>      >      >     Please help me check it out and report back if there are any problems during our release
>      >      >     <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>>>>
>      >      >     /Yours Sincerely,/
>      >      >     Pham Quang Duong
>      >      >     <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>>>>Tell: +84 389799932
>      >      >     /phamquangduong at ifee.edu.vn/ <http://phamquangduong@ifee.edu.vn/> <http://phamquangduong@ifee.edu.vn/ <http://phamquangduong@ifee.edu.vn/>> <http://phamquangduong@ifee.edu.vn/ <http://phamquangduong@ifee.edu.vn/> <http://phamquangduong@ifee.edu.vn/ <http://phamquangduong@ifee.edu.vn/>>> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn>> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn>>>>
>      >      >     *Department of Research and Development**Institute For Forest Ecology and Environment*/http://ifee.edu.vn <http://ifee.edu.vn> <http://ifee.edu.vn <http://ifee.edu.vn>> <http://ifee.edu.vn <http://ifee.edu.vn> <http://ifee.edu.vn <http://ifee.edu.vn>>> <http://ifee.edu.vn <http://ifee.edu.vn> <http://ifee.edu.vn <http://ifee.edu.vn>> <http://ifee.edu.vn <http://ifee.edu.vn> <http://ifee.edu.vn <http://ifee.edu.vn>>>>/
>      >      >     <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901> <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>>>>_______________________________________________
>      >      >     QGIS-Developer mailing list
>      >      > QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org> <mailto:QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>> <mailto:QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org> <mailto:QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>>>
>      >      >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>>>
>      >      >     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer> <https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>>>
>      > /Yours Sincerely,/
>      > Pham Quang Duong
>      > <https://htmlsig.com/t/000001DFX901 <https://htmlsig.com/t/000001DFX901>>Tell: +84 389799932
>      > /phamquangduong at ifee.edu.vn/ <http://phamquangduong@ifee.edu.vn/> <mailto:phamquangduong at ifee.edu.vn <mailto:phamquangduong at ifee.edu.vn>>
>      > *Department of Research and Development**Institute For Forest Ecology and Environment*/http://ifee.edu.vn <http://ifee.edu.vn> <http://ifee.edu.vn <http://ifee.edu.vn>>/
> /Yours Sincerely,/
> Pham Quang Duong
> <https://htmlsig.com/t/000001DFX901>Tell: +84 389799932
> /phamquangduong at ifee.edu.vn/ <mailto:phamquangduong at ifee.edu.vn>
> *Department of Research and Development**Institute For Forest Ecology and Environment*/http://ifee.edu.vn <http://ifee.edu.vn>/
More information about the QGIS-Developer mailing list
