[QGIS-Developer] Problems configuring the statusBar
afernandez
afernandez at odyhpc.com
Sun Dec 11 13:05:04 PST 2022
Hello Andrea,
Sorry for the delay as it has been a busy Sunday with several commitments.
I've been trying to implement your proposed solution using different
approaches but still unsucessfully (even after trying different
combinations). From several posts, a potential syntax would be something
like:
variable1 = self.iface.mainWindow().statusBar().styleSheet()
variable1.setstyleSheet("background-color: black;")
However, this is not effective and 'variable' is returning
QStatusBar::item{border: none;}, which I'm unsure how to intepret or how to
define the variable so that setstyleSheet can be applied.
I also tried a more simplified version (following the suggestion at
https://stackoverflow.com/questions/23490017/how-to-add-style-via-setstylesheet-without-losing-orignal-style-in-qt):
However, it returns 'setstyleSheet' is not defined so it doesn't seem to
take setstyleSheet w/o an assignment. Do you have any suggestion on how you
would proceed?
Thanks,
AF
P.S. My apologies for the previous reply (it didn't go as anticipated)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221211/5c6d5d9d/attachment.htm>
