[QGIS-Developer] Building pyqgis doc locally
matteo
matteo.ghetta at gmail.com
Tue Dec 13 00:11:58 PST 2022
Hi Denis,
> yes you can limit what you build
> see https://github.com/qgis/pyqgis/blob/master/scripts/build-docs.sh
> <https://github.com/qgis/pyqgis/blob/master/scripts/build-docs.sh>
> either use --package core/gui/… or --class QgsVector (which will work as
> QgsVector*)
thanks, it works as expected!
Last (hopefully :) ) question: I'm adding some custom css in the
_static/css/custom.css file. I've also added:
html_static_path = ['_static']
html_css_files = [
'css/custom.css',
in the conf.py.in file, but when compiling sphinx is complaining:
WARNING: html_static_path entry '_static' does not exist
Do you have any idea why this is happening?
Cheers and thanks again
Matteo
> > Another approach is to do a PR on the repo, you will have a built
> > example at https://qgis.org/pyqgis/master_PRXX
> <https://qgis.org/pyqgis/master_PRXX>
> <https://qgis.org/pyqgis/master_PRXX>> (replace XX) when it's finished.
> and this can be done also to the forked repository right?
> you would need to enable the pages on your repo, I am not sure this will
> work out-of-the-box.
> > I believe it would require a bit of love to improve this workflow
> and
> > drop the gh-pages branch.
> > I hope this helps a bit.
> Thanks Denis
> Matteo
> > Cheers,
> > Denis
> > Le mar. 13 déc. 2022 à 08:14, matteo via QGIS-Developer
> > <qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> <mailto:qgis-developer at lists.osgeo.org>>>
> > a écrit :
> > Hi devs,
> > I've some small ideas to enhance the readthedocs theme of the
> pyqgis
> > documentation and I want make some local test before making a
> pull
> > request.
> > I've cloned this repository (around 7GB?!):
> > https://github.com/qgis/pyqgis <https://github.com/qgis/pyqgis>
> <https://github.com/qgis/pyqgis <https://github.com/qgis/pyqgis>>
> > and then I followed the instruction of the Readme file. It seems
> > building but it is literally taking ages (./build-docs.sh
> > -qgis-build-dir /home/matteo/dev/qgis-master/).
> > Am I doing something wrong or can I use some shortcut to
> build it? I'm
> > just playing with some css and eventually the config.py.in
> <http://config.py.in>
> > <http://config.py.in <http://config.py.in>> file.
> > Cheers and thanks for any advice
> > Matteo
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> <mailto:QGIS-Developer at lists.osgeo.org>>
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>>
> > Unsubscribe:
